Music lever question for two different music movements
justinabshire
Mar 7, 2021
24
The first question is when it is time to play the music the lever that goes in the notch falls back in and it stops the music from playing. The next question is the portion of the lever that stops the fan broke does anyone know where I can get a replacement.
2F56495D-0931-4874-835C-FCE9B4F3D264.jpeg B240B5DF-9454-4D17-A7B2-009E38F47EE2.jpeg
Vernon
Dec 9, 2006
988
123
At warning, the fan needs to be able to rotate when the (nose) pulls free of the cylinder, this will cause the cylinder to rotate very little because the warn wire is now blocking the fan but enough so that the nose won't drop back into the hole. At this point, (B) should be away from the fan and now (A) is holding it. Adjust at (A) and (C). The adjustment should also allow (B) to block the fan once the nose drops into the cylinders hole.
46,673
1,909
There should be a spring that pulls the lever backward a little when it comes out of the hole.
justinabshire
Mar 7, 2021
24
Thanks for the help I was able to get it running smoothly now
166,114
1,446,966
86,665
Furgus2021
2,883
