Music Box ticking sound
justinabshire
Mar 7, 2021
85
41
So I have noticed on this clock I am currently fixing when the music box plays there is a constant ticking sound from start to finish. If anyone has any suggestions please let me know no thanks ahead of time. I have included in this post a video which you can hear it when it plays.
POWERSTROKE
Jan 11, 2011
1,984
238
The brake wire shouldn't be between the lever that stops the drum. It should above it I believe. Don't have one in front of me.
justinabshire
Mar 7, 2021
85
41
I looked it over again and it seems that the brake is correct it moves out of the way and leaves plenty of room. Now being over powered I have the weight at 275. In conclusion the noise to me seems to come from a gear on the governor but was not 100% sure that is something.
50,163
3,303
It's a pretty fast repeat, so I would check the pinion gear. Probably cracked plastic.
19,692
4,719
There are presently two sizes of these little plastic gears/pinions available. Last ones I bought were from BFI @ 26 bucks for 5. On some you will have to replace the whole governor and that's a 'crap shoot' too. Willie X
POWERSTROKE
Jan 11, 2011
1,984
238
When you order a governor, how do you know what to order? I've done it and have had to file holes etc. but it's a pain to get everything lined up.
Latest posts
Staff online
184,167
1,608,554
56,057
LindaH7948
3,199
Removing A Movement From A Case by Kent
Top Bottom
