Hi again everyone,
Hope everyone in the states is looking forward to Spring and some nice weather.
I have had some issue with my Swiss Chalet Cuckoo Clock. Its having Music box problems.
Swiss hand craft Chalet Cuckoo circa 1960s
275G weights
Regula 30 Hr mov
1 day chains 3 weights
Functions - Cuckoo calling/Music Box Melody
2 doors - Cuckoo bird and Music man
The problem is the music box will not stop playing. Brief Process -
1. Cuckoo bird on the hour leaves clock housing and calls hour. The music box rod (located Left side attach to MB) is placed in front of the cuckoo bird perch rod. When the perch rod moves forward this dis engages the music box arm (5) The arm moves to Left.
2. When the music box arm moves to the left it activates the music box fly (see picture - above the 2 Spring) There is a metal rod (3) which dis-engages from a hole in the melody drum allowing the drum to rotate.
3. The melody drum rotates - MB ratchet moves around on weight of acorn and melody is played out.
4. On completing the melody cycle the melody drum then aligns with the - (3) position hole and the metal rod located at (3) is supposed to go back in the hole on the melody drum wheel and stop the song. MB arm (5) moves back to the right - stops the process and located behind (2 spring) is a bent rod which catches the fly and stops it from spinning.
5. (1) and (2) MB arm spring. Just beside (2) is another metal rod that goes behind the music man figures' rod and that slides back BUT the man is left out of clock and music continues until acorn crashes to the ground FAIL.
Issues --
The MB arm(5) is not moving very well could be the spring (located at 1 and 2) It should move almost half inch towards the left. (this process occurs after the cuckoo bird leaves)
Metal rod at (3) is not going into the hole.
Question?
Would it be easier to purchase a new music box? Just hard to find a place that would ship it and getting the part number?
Could the spring (1 and 2) have lost its strength?
Some feedback would be much appreciated and always I hope others will value from this, as I am sure its a re-occuring issue with many of these mass produced cuckoo clocks.
Keith
275G weights
Regula 30 Hr mov
Issues --
Question?
Keith
