Movement ID
Gustom Artistry
Apr 6, 2022
19
55
Can anyone help with what this might be? I was given this old clock today. I assume it was an old grandfather clock at one time...
wow
Jun 24, 2008
6,583
1,049
77
Pineville, La. (central La.)
It’s a new one for me. Never seen that movement. First stops I have ever seen like those. Someone else will know more.
Mike Phelan
Dec 17, 2003
10,891
333
West Yorkshire, England
Pendulum is too short for a grandfather. Given it's only a timepiece with two barrels and springs, I'd say it was essentisl to always work, but tttthere seems to no sign of it being a time recorder in a factory.
Gustom Artistry
Apr 6, 2022
19
55
Looks like a Seth Thomas that would be in a Time punch clock
I think you are correct. The one I have has been modified from something like this...probably followed someone home from work. Or less dramatic, was picked out of the trash.
bkerr
Nov 29, 2007
1,401
49
65
Canal Fulton,OH
This is from a time clock not the one posted above. This has wind indicators and geneva stops. These were so often cases that were cut down, the bottom discarded and turned into time only wall clocks. They are pretty cool piece of history, if you like that. Be careful if you intend to work on it. Springs are designed to power the time piece as well as the timing card stamp ( lower part ) Very strong. The EW can be damaged quickly as well if not taken down properly.
Reactions: Gustom Artistry
48,937
2,695
It appears to be a double wheel time only clock. Any other features would be activated by levers below the movement. Could be a separate movement for stamping time, a calendar, etc.
176,448
1,544,441
53,309
drohlin17
1,064
3,031
