movement caseing question
Discussion in 'Watch Repair' started by robert5556, Apr 6, 2012.
  1. robert5556
    robert5556 Registered User
    Dec 7, 2011
    464
    West Virginia
    I want to change the movement in a watch,how do I go about finding a replacement?What do I need to know as fare as mesurment and size?Thanks-Robert
  2. bjohnson
    bjohnson Registered User
    Feb 12, 2010
    41
    Ontario, Canada
    The easiest method is to replace the old movement with a new movement of the same calibre (and from the same manufacturer of course).
    The easiest way to find out the movement calibre is to look for stamped marks under the balance wheel .. unfortunately not all manufacturers put there marks there and the traditional way to ID a movement is to remove the dial and compare the setting works against sketches.
  3. robert5556
    Dec 7, 2011
    464
    West Virginia
    Ok,thanks.After 154 views there is finally a respone.I knew the calibre had to be the same but I wasnt sure how to find it.Also I didnt know if there were any other factors involved.Thanks again.-Robert
  4. Kevin W.
    Kevin W. Registered User
    20,163
    10
    Robert are we talking wrist watch or a pocket watch.
  5. robert5556
    Dec 7, 2011
    464
    West Virginia
  6. 441victor
    441victor Registered User
    Oct 24, 2011
    79
    Do you have a picture of the movement? Joel
  7. GeneJockey
    GeneJockey Registered User
    Mar 2, 2012
    841
    Scientist
    Possibly it took so long for a response because the answer could be anything from "that's easy, there are 5 of them on Ebay right now" to "you'll never find another one". It all depends on the movement, and the case and dial. So, if you have a picture, or any information like maker and caliber, that would allow folks to answer.
  8. robert5556
    Dec 7, 2011
    464
    West Virginia
    Im not trying to find the exact same movement,just one that will fit in the case.Thanks-Robert
  9. bjohnson
    Feb 12, 2010
    41
    Ontario, Canada
    Well .. that's harder.
    You need to find a movement that is the correct diameter, the correct thickness (or thinner and add a movement holder/spacer ring), and has the stem at the right height from the dial. Having dial feet holes in the correct locations to match your dial would also be handy.
    Good luck.
  10. robert5556
    Dec 7, 2011
    464
    West Virginia
Similar Threads - movement caseing question Forum Date
Mechanical WW Memovox movement removal Watch Repair Yesterday at 10:06 AM
Need help with removing the movement Watch Repair Oct 11, 2017
2974b balance staff question Watch Repair Oct 2, 2017
Mechanical WW Question about Bulova 11ANAC automatic movement Watch Repair Sep 18, 2017
Find or make a broken balance arbor for a cylinder watch movement Watch Repair Aug 29, 2017
