Movement and Pendulum
Discussion in 'General Clock Discussions' started by Lockland, Nov 12, 2019.
  1. Lockland
    Lockland Registered User
    Nov 7, 2019
    22
    Hi, can you please help look at the photos and advise me if the pendulum is original to the clock movement? The seller says they are original but I see the number on the movement and the pendulum do not match. Thank you...
    2A752FB9-C1E7-4CA0-BF43-163782A63B4E.jpeg 2A5CD92C-089E-4CDE-914C-4CCEE28EAE37.jpeg
  2. bruce linde
    bruce linde Technical Admin
    7,145
    909
    oakland, ca.
    it's an appropriate looking pendulum, but the crutch rod shows signs of lots of adjustments... unless you moved the bob down? it might have been on a similar movement and adjusted when put in place... don't think it matters that much (unless the clock itself is exceptional and would be significantly more valuable all original). it wouldn't bother me (subjective opinion!)
  3. Lockland
    Nov 7, 2019
    22
    Thank you. So the pendulum is not original to the movement then. It’s okay for me too, I just want to check with others to make sure that I understand it right.
  4. bruce linde
    7,145
    909
    oakland, ca.
    i didn't say that... it looks correct, but there's a shiny spot on the shaft near the top of the bob that makes it look like the bob has been lowered... more than just a bit. maybe that's you, maybe that's someone else, maybe it's not original... no way to tell, really.
  5. Lockland
    Nov 7, 2019
    22
    Oh sorry :) It has been like that since I first saw it, so it should be the seller who adjusted it to make the clock works. But in this case, I can’t use the method of matching the printed number on both the pendulum and movement to check their originality? I was thinking that it is the only way...
  6. bruce linde
    7,145
    909
    oakland, ca.
    ok, i now think non-original. why? because the pendulum bob says 5 5 and the back of the movement says 7 2.
    read this article for more: http://www.abouttime-clockmaking.com/downloads/French%20Clock%20Beat%20Rates2.pdf
    the ultimate test, though, is whether the clock keeps accurate time with the pendulum you have. if yes, i wouldn't worry about it. if no, you probably need a different one.
    p.s.: i ain't no expert, and i'm not sure why those with more info are hanging me out to dry! :cool:
  7. new2clocks
    new2clocks Registered User
    NAWCC Member Sponsor
    Apr 25, 2005
    2,483
    292
    Pennsylvania
    Interesting article that you linked.
    Based on that article (Table 4), if I am interpreting it correctly, the OP's pendulum should have a length of 194 mm or 7.638 inches.
    If the measurements match to the above, then the pendulum is correct (note that I did not say original) for his movement. This also implies that the "5 5" on the bob was not meant to equate to the "7 2" on the movement.
    On the other hand, if the OP's pendulum length is 146.36 mm or 5.773 inches then it is not correct for the movement and is not original to the movement.
    Regards.
  8. JimmyOz
    JimmyOz Registered User
    Feb 21, 2008
    522
    94
    I may be missing something, however the movement does not have a number stamped on it, Look at the edge of the bezel as there could be a number stamped on that. As pointed out though the pendulum has a length stamped on it as does the clock movement and these being different says to me they did not start life together, however it looks to be about the same age of the clock movement. Having a pendulum different to the clock number is no big deal on lower end of the market as it is more the norm they are different than the same. Over the 130+ years the clock has moved many times and you have to take out the pendulum to move it, then it gets lost and you find another, just happens that way it seems.
  9. bruce linde
    7,145
    909
    oakland, ca.
  10. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    4,876
    155
    Devon
    The important thing is whether the pendulum is suitable for use on the movement to keep accurate time, as in can it be adjusted to have an effective length of 7 pouces and 2 lignes.
    Imo it isn't original to the movement and I've also never come across or seen a French pendulum bob with the length marked on it.
  11. Lockland
    Nov 7, 2019
    22
    Thank you all for your kind reply. They have been extremely helpful in broadening my knowledge about old clocks. In fact, the provided pendulum is keeping the time very well despite it’s not original (also my opinion).
