Albert Rambaud
There are important technical advantages in how the Rollimat operates compared to the traditional pivot polishers. Using the Rollimat, the clock wheel remains stationary, while the carbide wheel rotates around it. As a result, clock wheels with pinions or the brass gear near the pivot are easily done without fear of breaking a pivot. The clock wheel is not chucked into a lathe. So wheels such as a warning wheel with a pin sticking out is not at risk. There are several you tube videos on the motorized version. We have a very short video on Hand Rollimat we carry. It is designed to be hand cranked, but we attached a small lathe motor to it. We believe the advantage to this model is that there is more control over the speed and the work. It is also about a thousand dollars less expensive than the regular motorized Rollimat. If interested in seeing it, kindly contact me at butterworth@butterworthclocks.comI have had a Morgan pivot polisher for a few years and sadly it stopped working a week ago.
How does the Morgan pivot polisher compare to the Rolimat? I know the Rolimat is more expensive but does it actually do a better job?
