ATO More shipping woes
Discussion in 'Electric Horology' started by MartinM, Aug 10, 2018.
  1. MartinM
    MartinM Registered User
    Jun 24, 2011
    3,053
    102
    El Dorado, CA
    It definitely didn't look like this in the auction listing.
    The glass is an easy fix.
    The coil covers are the worst I've ever seen.
    Anybody have the coil winding specs for this one?
    One real coil set and one dummy)
  2. etmb61
    etmb61 Registered User
    Oct 25, 2010
    2,479
    167
    Retired Avionics Technician
    Mascoutah, IL
    I hope you got some compensation for that! I purchased two of those in the past year. The first lost the coils and the glass and the second just the glass. These just don't ship well.
    I can get you the resistance of the coil on mine and you could figure the approximate length of wire needed from that.
    Eric
  3. MartinM
    Jun 24, 2011
    3,053
    102
    El Dorado, CA
    There's actually a label on what's left that says 1450 ohms. I don't know of that's the impulse of sense coil or all together. Is it generally something like 10 to 1? And would the sense be the inner coil?
    This gives me the incentive to install that digital tachometer/counter I bought for my metal lathe.
  4. sophiebear0_0
    sophiebear0_0 Registered User
    Nov 5, 2012
    77
    That really does look to have been badly mistreated.
    Unless I am mistaken, I think this ATO model is mechanically switched. It would then just need a single impulse coil.
    The ATO coils are normally wound with 42 AWG enamelled copper wire. This has an electrical resistance of 5460 ohms/km. So if you are looking to achieve 1450 ohms, you will need approximately 270 metres. The number of turns will obviously depend upon the bobbin dimensions.
    The actual resistance is not overly critical in the mechanically switched ATO's. I have a number and they range between 1200 - 3000 ohms.
    The last coil I wound took about 4000 turns to achieve 1250 ohms. The bobbin id was 14 mm and height approximately 8mm.
    You may wish to await feedback from others who actually have the same model.
    Peter
  5. etmb61
    Oct 25, 2010
    2,479
    167
    Mascoutah, IL
    Martin, mine reads 1500 ohms. As Peter pointed out there is only the one coil, the switch, and the battery in the circuit.
    Is there a number on the back support plate of your clock?
    Eric
  6. MartinM
    Jun 24, 2011
    3,053
    102
    El Dorado, CA
    Thanks, all. That simplifies the whole fix, greatly.
    I was so shocked to see the coil laying out there like that... I didn't think about how this clock differs from the KundOs I've been messing with.
    Oh yeah, Eric... The number on the back is 525973.
