• Upcoming updates
Morbier sounds flat and tinny
Morbier
New User
Nov 30, 2022
We have a Morbier Repeater. I know little about clocks, but my father brought this back from Normandy years ago and we now have the honor. We love the clock, but question if the chime is sounding as it should. From the second photo you can see the coil chime mechanism. The chime is muddy and flat. More of an off-key, "bong." Does anyone know if that is appropriate for this clock?
Mike Phelan
Dec 17, 2003
11,055
408
West Yorkshire, England
Hi,
It doesn't chime, but strike :)
The striking should sound good and deep. We cannot see the hammer but there are several ways it shouldn't seem well so it will be better if we can a close-up to where the hammer strikes the gong at rest and take it from there.
The gong might not be tight, the hammer resting on the gong or have a pad on it etc etc ...
Reactions: Robert Gift
demoman3955
Apr 9, 2022
505
148
66
I had a drop octagon clock that sounded really bad, and i tried everything to get it to sound normal. Took a gong off another clock and it was perfect. The actual gong got rusty and it killed the gong itself. I even tried to clean the gong but it made no difference.
Vernon
Dec 9, 2006
1,369
249
57
Sound could change if there is a split or crack in the wood or if the wood isn't attached solidly.
Vernon
nutmegtinker
Dec 25, 2020
92
11
CT
View attachment 738493 View attachment 738494
I just finished restoring one of these. Mine just hangs on the wall but, has a gong that looks the same as yours. It is attached to its own sound board. Mine also sounded bad and I tweaked it so that it is much better. There are a number of things that can affect the sound. Here are a couple of things to check:
Is the hammer falling freely? Observe the strike cam (star wheel) as it is striking. Is it lifting and releasing fully; or, is the timing off?
Look at the hammer arbor. It has a little paddle mounted on it at a right angle that has a stop which catches it as the hammer drops. There is also a spring on the arbor which rests on this paddle. On mine the spring is adjustable to several positions on that paddle. You might try to adjust that spring and observe the hammer drop. It needs a little "bounce" or it will sound flat.
Observe the hammer as it strikes to see if it landing square on the wire. Mine was slightly off so, I gently bent the wire until it landed square. That made a huge improvement.
Finally, check that the leather wadding on the tip of the hammer is present and not badly worn. That can be readily replaced if necessary.
Basically, you need to observe and get to know how it works and then tweak as necessary. I do not have a broad experience with the Morbier clocks but, I suspect that their gongs never sound very melodious. I am open to be dissuaded from this notion but, in the meantime I have also rigged up a simple sytem to disable the striking temporarily (for visitors).
wow
Jun 24, 2008
6,981
1,241
77
Pineville, La. (central La.)
If we could see and hear it striking, we could probably help. Could you make a video on YouTube and post it here?
179,022
1,570,257
54,047
aztrukin
909
3,088
Swiss Fake by Kent
