Morbier - hodge podge
James Lucas
Aug 25, 2020
179
21
Hello All, A friend of mine picked this up at a clock shop that was going out of business.
I've only had one experience with a Morbier and have done some research but found nothing that looks like this. The dial is one piece and the pendulum doesn't look like it belongs either. The wood box has a hook on the side and holes on the other for hinges. Would appreciate any input.
Thanks,
James
Pic 1.jpg Pic 2.jpg Pic 3.jpg Pic 4.jpg Pic 5.jpg Pic 6.jpg Pic 7.jpg Pic 8.jpg Pic 9.jpg Pic 10.jpg Pic 11.jpg Pic 12.jpg Pic 13.jpg Pic 14.jpg Pic 15.jpg Pic 16.jpg Pic 17.jpg Pic 18.jpg
tracerjack
Jun 6, 2016
2,956
733
Lodi, CA
I have zero experience with Morbiers, but I agree that the motif of the dial does not seem to match the pendulum, although it is a very interesting pendulum. The dial is gorgeous. Hopefully, my post will bring your thread to the attention of someone who is familiar with these movements.
James Lucas
Aug 25, 2020
179
21
Thanks for the comments. I've since repaired the pendulum but still think it doesn't belong nor does the dial. Hopefully you're right and someone with experience will reply.
James
5,809
1,014
The dial used in these clocks was normally a white enamel dial. The wooden box is a home-made solution to hang the clock to the wall. In most cases an iron bracket was used for this purpose.
James Lucas
Aug 25, 2020
179
21
Thanks Uhralt, The dial is not right for what I've seen. Any thoughts on the pendulum? I just can't seen it with this clock..
James
Vernon
Dec 9, 2006
1,392
259
57
The pendulum is interesting in that it appears to have animation. A friend has one with a different design. The pendulum has a thin wire or line that goes from the bottom then up the length to terminate somewhere at the movement? He doesn't have the clock working but hopes to soon. These seem rare to me.
Vernon
JimmyOz
Feb 21, 2008
1,372
476
67
Gold Coast Qld
I think the pendulum is correct with the movement and top piece surrounding the dial, however I don't think the dial is. Here is one I had with animation.
The wooden box around the movement is replacing the metal side doors and back and I am not sure the gong is correct, all the others I have had and repaired had a bell on top.
James Lucas
Aug 25, 2020
179
21
JimmyOz, Thanks for sending the photo. The pendulum looks to match the surround. Not sure where I'll find a surround to match the pendulum of my friends clock. The wire gong is correct for the time period according to Lawrence Seymour 1860-1916.
James
tracerjack
Jun 6, 2016
2,956
733
Lodi, CA
You posted that the dial is one piece. I assumed that meant the dial and the surround were a single casting, that the dial could not be separated from the surround. If that is the case, then while unusual, it would have to be original. If my assumption is wrong, then yes, the brass face looks odd, even with my only experience with Morbiers being the posts and photos I’ve read on this forum.
James Lucas
Aug 25, 2020
179
21
Yes it is one piece. It wasn't mounted on the frame when he brought it over and now I see where the mounting holes don't match up with the frame. Should have made a closer inspection before posting. Another lesson learned.
James
tracerjack
Jun 6, 2016
2,956
733
Lodi, CA
I think my terms were misleading. I meant whether the dial outlined in red could be separated from the surround (frame) outlined in green. If it were all one piece, then it would have to be original. But, I did understand your response, so it does seem the dial is wrong.
Support the NAWCC
Forum Expense plus NAWCC
Goal
$1,000.00
Received
$360.00
36%
Host server
$250.00
Software support
$250.00
NAWCC operations
$500.00
Expenses
181,325
1,582,139
54,771
rjjeffries
3,126
Top
