I'm trying to restore a French crown wheel Morbier, and am having the devil of a time getting the escapement set up properly. I've checked and adjusted the crown for flatness, roundness, and tooth height. The arbor is true, but no matter how I adjust the locking depth of the pallets I can't seem to get it going. While slowly operating the escapement by hand, either both pallets catch and won't let the tooth get by, or the escapement runs away. I've checked the running of the crown in the lathe as-well-as in the movement; it looks as true as can be. With the pendulum attached and in beat (for the few consecutive teeth it will run on) the pallets are engaging equally, but the depth is very slight. I'm using 8 pound weights, and the train appears to be sound in all other respects. I can't believe adjustment of these movements is normally this touchy. I'm sure I'm missing something basic, but can't see it. Can anyone give me some ideas?
