Hello,
This is the second time I'm trying to post this. I could not find the first one on the site. I apologize if this is duplicated.
I purchased what I believe to be a center wind Mora clock movement and dial. Photos are included here. The plans are to get it running and build a correct case for it. This is my first Mora and, I have some questions.
It came with a brass cable and pulley for the weight. Is this correct or should it be gut line? If it should be gut, what thickness should it be? I've read that the weight is 10 pounds.
Are the roman numerals waxed or painted? Some of the black was damaged and was repaired with magic marker. Other places the metal shows through.
The alarm function has a separate narrow drive pulley with a wheel that has triangular teeth at the bottom for grip maybe? What kind of cord or gut line to use? I'm guessing the alarm weight is very light, maybe one pound?
The alarm hammer has no spring or detent to keep it at rest position. It doesn't look like there was ever any either. Is this normal?
Thanks in advance for your help.
Mick Martel
Mick Martel
