Model 1904 main wheel
richiec
Feb 24, 2007
7,129
834
68
Brick, Ocean, NJ
I recently purchased a Waltham 1904 because I didn't have one, it is a 14 size movement. I know these are an evolution after the 1888, 1895 and 1897 models. The issue with this movement was the mainspring was broken, someone had adapted a different spring and folded it over to catch the hook, the size is identical to the 2218 spring so no issue there. The center wheel cannon pinion arbor was broken off, the gear is the same size as the 1888 but the lower plate arbor is .078 inch in diameter while the 1888 arbor is .100 inch. There are no catalog listings for parts for these primarily export movements so I am wondering if I will need to find a donor movement, few and far between these days or if someone has an extra wheel. The serial number is 19155530 if that is any help. 7 jewels, OF, Bond St grade.
NC Plumber
Jan 15, 2011
413
22
I will look tomorrow, I'm fairly certain that I have a few 1904 parts movements.
Smudgy
May 20, 2003
2,874
25
If NC Plumber doesn't have what you are looking for try posting in the Parts Wanted forum (under Horological Miscellany).
171,031
1,493,248
50,084
Genda
2,967
