Mobil 1â„¢ 15W-50 full synthetic oil at Walmart. $6.95/qt.
Discussion in 'General Clock Discussions' started by Robert Gift, Mar 19, 2017.
  1. Robert Gift
    Robert Gift Registered User
    Nov 12, 2012
    184
    Tree service "Branch Manager". Medical courier
    Denver, Colorado
    Would it be OK to oil the 1977 and 1979 Ridgeway grandmother clock Franz Hermle clock movements with it?
    Would the oil's additives be an issue?
    After using one drop in the clocks, would use the rest a few ounces at a time in the vehicles.
    Thank you.
  2. MrStretch
    MrStretch Registered User
    Feb 21, 2017
    17
    In a word, no. Use good quality synthetic clock oil.
    Motor oil is wrong for clocks for a variety of reasons - contains detergents(bad), is hydroscopic (designed to absorb water, very bad) and may not play well with copper alloys (also bad)
  3. dickstorer
    dickstorer Registered User
    Oct 19, 2010
    558
    Retired Military
    Hampton, Georgia
    I guess I am in bad trouble. I have been using Mobil 1 for several years and as far as I can tell I have never had a come back due to using it. I will be eager to read any more comments.
  4. Robert Gift
    Nov 12, 2012
    184
    Denver, Colorado
    Re: Mobil 1â„¢ 15W-50 full synthetic additives
    What viscosity do you use? (I did not know they made 15W-50.)
    Would be nice to see close-ups of the pivots and holes to discern if the Mobil 1â„¢ additives have caused damage.
  5. Time After Time
    Feb 22, 2010
    3,104
    11
    Retired General Dentist
    Yes. I think it would be fine. The biggest knock with using Motor Oils, in my opinion, is that the formulas do change so you may not be able to buy something you've used in the past. You'll get a wide variety of opinions on lubrication on this Message Board. I've used Synthetic Mobil 1 0W-40 (for about 2 years) and Synthetic Castrol Edge Gold 10W-60 (over the last year) on our clocks. I've been very pleased with the results thus far. Admittedly, that's not a long time as far as clock maintenance goes. I've also used Ney Synthetic Clock Oil on some of our Grandfather Movements and have been disappointed by its performance on 1st & 2nd Wheel Pivots. It's too thin and it doesn't stay put very well...again...in my opinion.
  6. Hudson
    Hudson Registered User
    Jul 19, 2010
    134
    Spicewood
    The 15w-50 would be just fine for the lower pivots, but you may want to consider a lighter grade for the uppermost ones.
    You will find many conflicting opinions and oil recommendations for clocks. I'm convinced that synthetic engine oils are just fine for clocks. You can find the opinions in previous threads on this board.
  7. Robert Gift
    Nov 12, 2012
    184
    Denver, Colorado
    The 0W-20 used in our vehicles could be used for the upper pivots. Is it too light to use everywhere?
    Why are VERGE PIVOTS not oiled?
  8. MrStretch
    Feb 21, 2017
    17
    Why? What's the point?
  9. Robert Gift
    Nov 12, 2012
    184
    Denver, Colorado
    #9 Robert Gift, Mar 20, 2017
    Full synthetic. It's cheap compared to clock oils. I can get it. Haven't been able to get to clock shops while they're open.
    Leftover oil would be used in the vehicles.
  10. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,867
    watchmaker
    Western NSW, Australia
    It isn't clock oil. Sure I use some oils and greases for some things that aren't actually watch or clock oils but that is mainly because at times the real thing wasn't available. Clock and watch oils may be expensive to buy but the bottles take forever to empty. you could perhaps take some car oil off the dipstick of your car if you desperately needed some.
  11. John Hubby
    Sep 7, 2000
    11,210
    19
    The Woodlands, TX
    #11 John Hubby, Mar 20, 2017
    I have used full synthetic motor oils for over 25 years now with ZERO problems; I service in the order of 100 clocks per year and have had ZERO comebacks due to lubrication.
    I own three 400-Day clocks that I did some testing on starting in 1996 that I disassembled in 2001, 2006, and 2011 to check mainspring and pivot condition. One was lubed with Mobil 1 10W40 (mainspring) and 0W30 (pivots), one with Slick 50 HP (no longer available) for the mainspring and Etsyntha 5 (no longer available) for the pivots, and one with Slick 50 HP for mainspring and pivots.
    NONE of them have required re-lubrication of the mainsprings and all are still running (going on 21 years). At each check the mainsprings had a slightly wet appearance, no crud and no evidence of stickiness, thickening, or corrosion. The springs were reinserted in the barrels and placed back in service each time without adding any oil. I'll check them again later this year, didn't do that last year due to other priorities.
    >> Mobil 1 performance:
    No mainspring issues as noted. This clock required cleaning and relube of the pivots in 2011 (15 years service). The top end pivots had "dried out" although no evidence of wear and the clock was still running at the time. In this service I used Mobil 1 5W30 for the pivots, slightly higher viscosity based on recommendations from others who started using this oil in the same period I did.
    >> Slick 50 HP plus Etsyntha 5 performance:
    No mainspring issues as noted. This clock also had dry pivots but happened in 2006 after 10 years operation. I changed to Slick 50 HP and no problems since then, but I'll run out of my supply one of these days and it's no longer available. Etsyntha 5 has been replaced by Etsyntha 859, I have not used any of it so can't report.
    >> Slick 50 HP performance:
    No mainspring issues as noted. All pivots had visible oil present at each inspection although the oil is darkening with time. Will plan to clean and relube the pivots when I do the next inspection.
    Other observations include:
    >> Neither the Mobil 1 nor the Slick 50 HP had any problem with oil migration from any pivot holes.
    >> There is no metal discoloration with any of the lubes used in these tests, either around the pivot holes or on the pivots/arbors.
    A final comment:
    My interest in synthetic lubes started with finding that Nisshendo Watch Co. of Japan (Master TM) used synthetics for their mainspring lube from the earliest production in the 1950s. In the early 1960s they introduced 100-Day and 200-Day clocks that had sealed mainspring barrels that can't be opened without severe damage, evidently based on their confidence the mainsprings would never need servicing. I opened a couple of these in the late '90s just to check, and in those cases found the mainsprings to be in perfectly good condition, slightly wet with lubricant, and still with their original blued color after more than 40 years in service! I don't know what lube they used except that it has been analyzed and found to be 100% synthetic of about a 10W viscosity. My use of Slick 50 HP was based on their theory that the presence of colloidal Teflon would result in teflon being impregnated in the mainspring coil surfaces and result in much lower sliding friction. I carried out a series of tests in 1997-1998 using three 30-Day clocks and three mainspring lubes (Moebius mainspring grease, Mobil 1 10W40, and Slick 50 HP) that strongly supported that premise, with Slick 50 HP averaging about 23% longer run times than the Moebius grease and Mobil 1 giving 16% longer run times than the Moebius grease. That test is described in more detail in a post in this forum that was linked by Kurt.
    One other test I've carried out is to use Slick 50 One-Lube spray on mainsprings. My experience is that performance is excellent but no better or worse than Mobil 1 10W40. Being in a spray can makes it more convenient to use but it's a bit more expensive.
    Long story short: Since Slick 50 HP is no longer available, today I would choose Mobil 1 for my clock lube, 10W40 for mainsprings and 5W30 for pivots and never look back.
    EDIT: I've edited the comparative run times for the three lubes to conform with the actual results shown in the thread linked by Kurt, my memory was just about right but really need to use the source data. :cop:
  12. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    1,696
    Aerospace Engineer
    San Antonio, TX
  13. BLKBEARD
    BLKBEARD Registered User
    Nov 15, 2016
    619
    HVAC, MECHANIC
    CT
    I'm pretty sure that only the 1st number matters when using multi-grade/multi-viscosity motor oil in clocks. 5W-30 is 5w cold the 30 number is the high temp viscosity rating. a clock will never see temperatures required to change the viscosity. So 10-30, 10-40, 10-50 is all the same in this application. 5W-X, 10W-X, 15W-X, 20W-X would be your difference in this application.
    https://en.wikipedia.org/wiki/Motor_oil
    Scroll down to multi grade
  14. Time After Time
    Feb 22, 2010
    3,104
    11
    #14 Time After Time, Mar 21, 2017
    Yes, I would use the lighter viscosity oil beginning with the third wheel in the train on up to the Flys and Escape Wheel. Use the heavier viscosity on the first and second wheels. I alluded to that earlier but I should have stated it explicitly. Thanks Hudson for pointing that out.
    Regarding the Verge Pivots, we're getting into a whole 'nother area now. Some folks do oil the Verge Pivots. I always do. You'll definitely want to use a low viscosity there. I also apply a little oil to one of the pallets and let it distribute to the tips of the escape wheel's teeth.
    Most folks don't recommend oiling gravity powered levers and such, like Racks, Rack Hooks, Long Levers and such. The reason being that the oil tends to dry and gum up...that has been true of many of the older clock oils. Not so sure that it applies to the synthetics as much but you won't go wrong by leaving these surfaces clean and dry. Since you're not disassembling this movement you may want to be sure that these control levers move freely. If they don't you can carefully remove them and clean the pivot surfaces without disassembling the rest of the movement.
    I'm not sure if that fully applies to the modern multi-viscosity formulas BLKBEARD. What about the 0W-X oils? I use such a formula and it definitely has more viscosity at normal room temperature than does my Ney Synthetic Clock Oil. Just as clocks will not be operating at high temperatures, they won't be operating at freezing "Winter" temperatures either (Tower Clocks excluded). There are many different formulas out there and they change relatively rapidly. I do agree that the bottom number should serve as a good baseline. i just know that 0W-X is not "water" at room temps.
  15. Time After Time
    Feb 22, 2010
    3,104
    11
    John, thank you for taking the time to review your experiences with the use of these types of lubricants in Horology. I always get a little nervous recommending them because some folks hold very strong opinions against using motor oils in clocks.
  16. Whereisitat
    Whereisitat Registered User
    Mar 14, 2017
    47
    Here is my "secret" recipe...
    1/3 portions each...Mix well, stays in solution fine.
    30W non detergent motor oil
    STP with Zinc additive(standard blend)
    Rem-Oil from the can-spray into cup for measure.
    Great for all drive pivots. Smaller watches in main barrel/pivots. Tested it by putting a dot on a plate of steel-hit it with a micro torch for a full second. It stayed put & was still solute.
  17. roughbarked
    Dec 2, 2016
    1,867
    watchmaker
    I've used lots of oils that aren't specifically clock oils. For example I use a white grease made specifically for the upperv asslembly parts of outboard motors to grease the Seiko auto pawls. It is Valvoline X-All.
  18. shutterbug
    34,341
    30
    I think the verge pivots issue is related to the "oil only the parts that rotate 360°" rule. So you would normally not oil strike lever pivots and things like that. But the verge is in motion almost constantly, and I always use a bit of oil on the pivots there.
  19. Mr. Time
    Mr. Time Registered User
    Feb 13, 2017
    47
    TEXAS
    #19 Mr. Time, Mar 22, 2017
    After reading all the post on this thread I went directly to my clocks owners manual and specifically read under the "Care and Maintenance" section of the manual and read about oiling the clock's movement.
    Well the manual is not specific about two things: 1.) What type of oil (clock oil?....maybe gun oil?.....etc.?) grade, etc. should be used?.....and......2.) Where exactly on the clock movement or at what specific points on the clock movement should one apply oil too?
    I have a Howard Miller MacArthur mantle clock (http://cql.howardmiller.com/Product/Details.aspx?StyleID=754) which was purchased back in Sept. 2009.
    After inquiring with Howard Miller, specifically with serial number, my MacArthur clock was produced/manufactured in the year 2008. Production on the Howard Miller MacArthur clock was started back in the year 2003.
    I have again, contacted Howard Miller to inquire about what specific clock oil should be used as well as where or what points on the clock movement should oil be applied to, etc. The manual does not indicate this specifically nor does it show any diagrams, etc. all it says is that oil should be applied to the clock movement and that's about it?
    NOTE EDIT: Looks like I found an answer to at least one of my questions concerning clock oil type. Since I posted this, I checked the Howard Miller website and under the Customer Help Center questionair, the last question pertains specifically to the clock oil recommendation (http://cql.howardmiller.com/FAQs/Default.aspx?FaqCategoryID=14&FaqCategoryCode=DFLT) clock oil 859.
  20. davefr
    davefr Registered User
    Nov 29, 2008
    350
    Semi Retired Engr. Mgr - Currently Rebuilding Tele
    Oregon
    The additive package in motor oils is formulated to deal with the byproducts of combustion. (hardly needed in a clock).
    I think an ATF or Hydraulic/Tractor fluid would be better.
    However what's the point when there's products designed to deal with the unique lubrication properties of clocks?
  21. Mr. Time
    Feb 13, 2017
    47
    TEXAS
  22. leeinv66
    leeinv66 Super Moderator
    Donor NAWCC Member
    Mar 31, 2005
    8,000
    12
    Industry Specialist
    Launceston Tasmania
    Are they? Or are they just packaged to appear that way? I have brought many different clock oils over the years and some I wouldn't use to oil my wheelbarrow.
  23. davefr
    Nov 29, 2008
    350
    Oregon
    As long as you use the correct viscosity it probably doesn't matter much. Modern lubricants are far superior to the old primitive lubricants that the clock manufacturers had available at the time.
    I thought the main advantage of dedicated clock oil was that it had a little more "cling" to stay where it's placed.
  24. BLKBEARD
    Nov 15, 2016
    619
    HVAC, MECHANIC
    CT
    I wonder if anyone has tried Chain Saw Bar & Chain Oil? winter weight is 20W, summer is 30W. It's designed to stick in place and not run off.
  25. leeinv66
    Donor NAWCC Member
    Mar 31, 2005
    8,000
    12
    Industry Specialist
    Launceston Tasmania
    Yes that is true Dave, that "cling" thing is what clock oils are suppose to do. Unfortunately, not all do as advertised.
  26. harold bain
    Donor NAWCC Member
    39,950
    Yeah, I use it all the time (in my chainsaw). Too thick for pivots, and probably same for springs. Not made to last long, since I have to keep refilling it.:whistle:
  27. BLKBEARD
    Nov 15, 2016
    619
    HVAC, MECHANIC
    CT
    If you stop using bar & chain oil you won't need to keep refilling the reservoir & the chips wont stick to your chain. Plus you'll have the added benefit of a designer blue chain.
  28. bangster
    bangster Super Moderator
    16,313
    20
    My rule is: Don't oil anything that relies on gravity for its operation. On that basis, I oil verge pivots since they are driven by the ew.
  29. leeinv66
    Donor NAWCC Member
    Mar 31, 2005
    8,000
    12
    Industry Specialist
    Launceston Tasmania
    Oiling the Verge pivots and the pallets contact faces is a must in my opinion.
  30. roughbarked
    Dec 2, 2016
    1,867
    watchmaker
    :) a sensauma is a valuable thing.
    - - - Updated - - -
    They don't work long without it.
  31. David Mac Farlane
    David Mac Farlane Registered User
    Aug 4, 2016
    25
    Authorised person - Mechanical, POL, DAVS and Elec
    Leven, Fife, Scotland
    Extralube ZX1 - if we're talking synthetic oils - this has to be worth looking at - A friend lost his sump and drove 40 miles before he discovered it - no damage to surfaces - another friend swears by it in his gun mechanisms -I've used it on lots of things.
    The word for water absorption from the air, incidentally, is hygroscopic.
    Read the specs on this stuff (ZX1)- it is not PTFE, and is developed by the military - lets face it, WD40 does what it says on the tin - water dispersant - they developed that.
    It would be very interesting to have some microscopic comparisons for these oils - maybe by dropping some onto old brass, nickel, steel, and leaving them in fairly even temperature and humidity, indeed even experimenting with different levels of such,
    Our colleague who said they change synthetic oils constantly was right - they do, and sometimes to our detriment.
    I think the constancy of clock oil is where it smacks of quality - I don't think the spec changes that much.
    I think too, we've opened a can of worms for investigation - any oil manufacturers willing to take the torch:???:
    I know we won't make any millionaires, but when the technocrats get into power...............
    Dave.
  32. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    Since I am just a hobbyist, I've used a few different oils
    over the years.
    The one I like the best is Delvac, made by Mobil for Desiel
    engines.
    I suspect it has less additives than a gas engine oil. Desiel's
    oil runs cleaner than gas.
    I looked recently on their web page and see that they sell several
    different grades now.
    It might be a little difficult to buy now. I recall when I got it.
    My brother was using it in his race car for everything, including
    transmission and rear end. I saved a jug for other things at the time.
    It only came in gallon containers then and I recall he had to
    buy about 15 gallons at a time. Then, that was abut 40 years ago.
    I've not used it more than 12 years in clocks.
  33. THTanner
    THTanner Registered User
    Donor NAWCC Member
    Jul 3, 2016
    961
    Carson City, Nevada
    Has anyone tried Marvel Mystery Oil?
  34. glenhead
    glenhead Registered User
    Nov 15, 2009
    802
    10
    Telecom Engineer
    Williamson County, Texas
    Up in the upper corner of the window there's a white space that has a magnifying glass beside it and the words "Advanced Search" underneath. (At least that's how the screen appears on my monitor.) That's the search field. Type "marvel mystery" in it and either click the magnifying glass or hit Enter. 50 results. Read away.
    Glen
  35. THTanner
    Donor NAWCC Member
    Jul 3, 2016
    961
    Carson City, Nevada
    I should have been more clear with my question. I have found that Marvel Mystery Oil works very well as a cleaner for springs. It was basically designed as a flush for crud in the engine and has a lot of naphtha and other excellent solvents. I don't use it as a lubricant.
  36. David Mac Farlane
    Aug 4, 2016
    25
    We've learned something. :)
  37. sdowney717
    sdowney717 Registered User
    Mar 23, 2017
    34
    #37 sdowney717, Mar 24, 2017
    I use 0w-20 full synthetic oil, both Mobil1 and STP.
    The synthetic oil wont dry or gum up. And the carbonization point is much higher. Those oils work fine on electric fans where the speed of the bearing heats up and slowly carbonizes non synthetic oil.
    I also have dipped entire clock mechanisms in a bowl of 0w-20 then let it hang to drip dry. Wipe off after hanging a couple of days where beads of oil cling, never failed to work afterwards. The lighter oil will shed itself better than a heavier oil.
    One advantage of using 0w-20 engine oil, it dissolves corrosion. So some kind of slow working metal cleaner is in there.
    The cleaning effect is greatly enhanced with heat.
  38. THTanner
    Donor NAWCC Member
    Jul 3, 2016
    961
    Carson City, Nevada
    YES :) - - 1) put on paper what is in your head so people get an idea of what you are talking about, and 2) when you start a reply then get distracted - reread and edit before you go to lunch lol
  39. shutterbug
    34,341
    30
    This would be an interesting experiment, but I would never recommend it. Reminds me of spraying down an entire movement with spray-on oil. Makes an awful mess for the next guy.
  40. Kevin W.
    Kevin W. Registered User
    20,163
    10
    Might be a nice dust bunny after dipping it in oil.
  41. Time After Time
    Feb 22, 2010
    3,104
    11
    I don't think you can go wrong here bangster. It's a time tested approach. I do think that it may not be as crucial with the modern synthetics as they don't tend to "quickly" gum up like the old natural clock oils did. With some frequency I run across clocks with "green wax" binding up the pivots. I'm sure we all do/have. That kind of failed lubricant on chime hammer bearings, for example, would have them literally frozen in time. While I think it would be fine to use some low viscosity synthetic lubricants on pivots/friction points which rely on gravity for their operation, unless there's some indication of noticeable wear, I don't see any need to do so. In the vast majority of cases, based upon my limited experience, I agree with your advice here bangster. I'm sure that makes you feel much better, doesn't it? :rolleyes: Ha!
Similar Threads - Mobil 1â„¢ full Forum Date
full calendar grandfather clock movement... ? General Clock Discussions Aug 9, 2016
Twin fusee Full Westminster Chiming Clock General Clock Discussions Jul 8, 2016
History of full size No.1 banjo regulators General Clock Discussions Jul 9, 2015
Vincenti & Cie Mantle Clock - Marriage or Full Blooded? General Clock Discussions Aug 28, 2014
Mobil 1 Synthetic General Clock Discussions Jun 29, 2004
