Mixed wood veneer?
Discussion in 'Case Construction, Repair & Restoration' started by spxer, Oct 18, 2019.
  1. spxer
    spxer Registered User
    Jun 20, 2016
    I am restoring a Seth Thomas short drop wooden works clock. I have owned the the clock for around 50 years. I bought it in damaged condition. Case parts are missing etc. The veneer on the top appears to be walnut. So I am replacing it with walnut veneer and looking closer at the sides of the clock, they appear to be mahogany. The top (what there is left of it) does not appear to be replaced. Is it possible Seth Thomas made the clock with mixed wood veneers?
  2. shutterbug
    43,206
    1,189
    Yes. On some of their hanging clocks they used both Walnut and Rosewood, on others they used Walnut and Mahogany. Go with your instincts ;)
  3. spxer
    Jun 20, 2016
    Thanks. If I had some real mahogany veneer, I would go all mahogany. I don't, so it will have to be stained walnut. Picture shows the different veneer.
  4. spxer
    Jun 20, 2016
    Update on the rebuilding of the top. One corner repaired and the other made from scratch. I am using a repo eagle splat.
  5. spxer
    Jun 20, 2016
    Caps made and eagle fitted.
  6. spxer
    Jun 20, 2016
    Here is the case with the finish on. Despite my dark staining, you can see the difference in the wood on the tops above the columns. I am wondering if I should try to darken the top some more.
  7. gleber
    gleber Registered User
    Jun 15, 2015
    1,733
    193
    Underwater Robotics Expert
    Downingtown, Pennsylvania USA
    The work looks good, but I would darken them. It bothers me the way it is.
    Tom
  8. JTD
    JTD Registered User
    Sep 27, 2005
    7,494
    484
    Yes, I agree, the work is very neat but it does need to be darkened. It's a fine looking case - when you've finished, could you post a photo of the whole clock?
    JTD
  9. spxer
    Jun 20, 2016
    Added more stain over the finish. Looks good so far. I will let dry thoroughly and finish over that.
  10. tom427cid
    tom427cid Registered User
    Mar 23, 2009
    1,626
    86
    Cabinetmaker,clock repair
    Moultonborough,NH
    ditto,generally these cases were stained first with a wash coat of "barn red" then a dark reddish brown.
    hope this helps
    tom
  11. spxer
    Jun 20, 2016
    Here is the clock assembled now. Thanks to a certain website, I was able to find all the parts I needed.The movement, the dial, the hands, the bell, the splat, the pendulum, and the columns. I didn't start with much. I do need a painting on the lower to complete. I am too cheap to have one painted professionally. :chuckling:
    gleber likes this.
  12. spxer
    Jun 20, 2016
    A question about weights for a wooden works. Are they different from Ogee weights? I have these on hand. (picture) Would any of these be correct? DSCF0006 (1).JPG
  13. MikeA
    MikeA Registered User
    Old Timer NAWCC Member
    Dec 21, 2006
    64
    Retired engineer
    Slidell, LA
    For a 30 hr wooden works, should be about 3 pounds. I believe the 30 hr ogee are a little less.
