missing pinion gear tooth count... anybody? (ansonia long drop)
bruce linde
ADMIN / MODERATOR
8,895
1,386
oakland, ca.
clockhappy.com
my clock mentor asked i would ask you all if you could help:
"Can you please check with your sources on line for the teeth count and diameter of the missing pinion gear that drives the count wheel. The mvt is for a long drop Ansonia hour strike regulator. Thanks."
Dave T
Dec 8, 2011
3,617
212
NC
If I understand the question, I don't think there is any missing gear. The countwheel mounts in the plate with a spider spring clip.
Correct me if I'm wrong.
senhalls
329
western PA.
Didn't they use one long trundle on that lantern pinion ? That's why the count wheel has saw teeth form . Solder on the lantern looks like someone has been there before .
bruce linde
ADMIN / MODERATOR
8,895
1,386
oakland, ca.
clockhappy.com
he's pretty experienced and is thinking there should be a brass pinion similar to the ones below (from a gilbert). he had to fix a broken lantern pinion rod and thinks maybe the brass pinion part got lost when the damage happened.
64512388992__4FA40FA9-203A-4786-8A3F-3D425108C9C6.jpeg 64512431963__4ED7848C-7BD3-4BA3-9A9F-E27293769F01.jpeg 64512410568__ED3EA8E0-A1A3-4AF2-A3DE-A9A5CA92039E.jpeg
wow
Jun 24, 2008
5,274
554
76
Pineville, La. (central La.)
Well...........that's my story.......and I'm s....s....stickin' to it .
Your story is right. One or two (depending on the movement) of the pins on the pinion are longer than the rest, and as the pinion turns, it advances the count wheel. That missing pinion gear you are asking about is not missing. The solder on the end of the lantern pinion is where the longer pin was. Someone replaced it with the wrong pin.
Reactions: S_Owsley
bruce linde
ADMIN / MODERATOR
8,895
1,386
oakland, ca.
clockhappy.com
Your story is correct so stick to it. Here are a couple pictures from a similar Ansonia movement.
brilliant... and makes perfect sense.
senhalls - sorry i every doubted you! :)
Reactions: S_Owsley
bruce linde
ADMIN / MODERATOR
8,895
1,386
oakland, ca.
clockhappy.com
my clock mentor uttered the equivalent of 'doh!' and had the thing running in the time it took me to get over there to pick up some stuff. thx again, everybody.
167,196
1,456,970
87,357
PMcGinty
