IBM Missing glass from IBM Slave Clock
telechro
Dec 27, 2008
14
I have an IBM Slave clock that was installed in 1920 (Eastman Kodak, Rochester NY). The clock is missing the glass as well as the spline that held it in-place. All of my other slave clocks have the spline inside the case, however this one looks like the spline is on the outside. Since I don't have the glass or spline, I was wondering the size of both. If I have the glass cut to the edge, there is no room for the spline. I have part of a 1/4" spline which fits, but the glass then needs to be cut short
John Lippold
Feb 2, 2011
Hi Telechro, your clock originally had a circular wire hoop retaining the single strength protection glass. The diameter of the wire is approximately .200". The single strength glass is retained by the wire hoop using seven small brads which go through small .043" (#57 drill) holes drilled through the wire at 45 degree outward angles around the periphery of the wire. If you enlarge the photo I believe you can see the brads. The brads are located approximately at minutes 32, 40 1/2, 50 1/2, 60, 9, 19 & 28 1/2. The glass will have to be cut just a tiny bit smaller to allow room for the brads to go by the edge of the glass. Best of luck with your restoration... John
telechro
Dec 27, 2008
14
Thank you for the post, your clock looks great and it really helped me out. I tried one of the spring retainers from a newer IBM all clock with the convex glass, however that is too small. Since I don't think I'll be able to find the metal retaining ring, I'll use a wood spline the same diameter (these are easy to obtain as they are used for caning chairs.
telechro
Dec 27, 2008
14
I thought I would post a picture of the completed clock. I purchased a piece of chair caning that I cut to fit and hold the glass. I stained the caning to match the case used clear calking to secure the glass, frame and caning. It worked out great and the clock is working perfectly. Thanks again for your help and pictures...mitch.
Reactions: Dave T
Staff online
162,325
1,409,789
84,020
accuraterubber
2,854
Waltham Watches by Clint Geller
