Minute Hand for Junghans
Discussion in 'Clock Repair' started by Bill Cann, Jul 3, 2019.
Tags:
  1. Bill Cann
    Bill Cann Registered User
    Mar 26, 2019
    21
    I have a Junghans 12.14 movement with a 5" dial that needs a minute hand. The mount is a half oblong (3.5mm x 2.8mm) and canted 45deg (for some reason). Looked at my usual suppliers and they carry oblong hands but not canted, so not going to have much success filing it to 45deg. I have not turned up anything in minute hand bushings that size, either too small or too large. Also haven't turned up any hand blanks. Currently using an oblong hand I filed to fit and it is off by 45, but at least I can set the timing.
    The clock cleaned up nice, but the chimes at 7, 22, 37 and 52 minute marks are annoying. Any leads or suggestions are appreciated.
    Thanks, Bill
  2. JTD
    JTD Registered User
    Sep 27, 2005
    6,713
    347
    I am not sure that I understand exactly what you mean, but if the strike does not coincide with the hand position, you can turn the hand collet until it does.
    Use something like the tang of a file and insert it into the hand collet and turn in the appropriate direction. It may be very stiff, but it will turn.
    But perhaps I have misunderstood and you mean something else.
    JTD
  3. shutterbug
    40,799
    730
    I'll move this to clock repair forum for more exposure.
  4. Willie X
    Willie X Registered User
    12,017
    699
    Or, if no collet, something inside the clock is misplaced or bent. Willie X
  5. Uhralt
    Uhralt Registered User
    3,867
    387
    I agree with Willie. I have never seen a hand with a slot at an 45 degree angle. I think that probably the motion work has been assembled incorrectly.
  6. Uhralt
    3,867
    387
    I looked up antique Junghans clock hands on ebay, and the ones with the oblong hole had the long axis of the hole in the direction of the hand, as is usually the case. So my bet is that there is something wrong with the chime triggering mechanism. You will need to take the movement out of the case, move the minute hand manually and watch what exactly triggers the chime. This will help you to see what needs to be corrected. If you can, post a video to show what happens and we may be able to give you more direct advice.
