I'm working on a South Bend grade 219. There was a problem with the winding/setting mechanism and I replaced the clutch spring because the old one appeared a bit "stretched". Also it was pretty filthy so completely disassembled, cleaned and reassembled it and the train runs find. Problem is that the minute and hour hands don't turn. Center pinion turns but when I put the hour wheel and hands on, they don't work. Its like the center staff is spinning inside the center pinion. Any suggestions as to what the problem is
