I have been listening to the advice I have been given here, and have decided to try learning to redo bushings and polish pivots on several Hermle movements. I have been reading many discussions of bushings, but there are so many here that it is a bit overwhelming knowing where to start. My budget is limited, so I will be starting out with sub-optimal tools, but many here claim to do just fine with a few basics. So what is the minimum required for an acceptable job of rebushing and polishing (doing the job for myself, so it does not have to look professional, but I would like to have a good chance of it working for a while after I am done)? There is a good chance that I will disassemble and reassemble them several times, so I don't mind fiddling. I will start with pivots that are obviously worn, see what happens, then maybe move on to ones that have lesser wear. I have not yet decided on traditional bushings or butterbearings, so would like to be able to do either
I will be working on Hermle 1050 series or 1150 series movements. I can let down the springs. I have a small drill press and basic bits , but no needle files, no broaches, no reamers, and only basic hammers. I have some simple calipers good to around 0.01". So given my limited budget (maybe $100, up to $200 if things are significant must-haves) what else is absolutely vital? How about really useful? If you had to start all over from scratch, what would you buy?
How do I know what bushings I need?
Thank you all for your help.
