Re-sharpened carbide bits can indeed be useful, especially when re-pivoting. But be warned: they are not only very hard, but very brittle. Break one off inside the end of an arbor, and you have a Situation. They need to be handled with a light touch to avoid breakage.![]()
The older type carbide drills used in dentistry are often useful. They are known as straight handpiece burs and have the same same shank diameter as Dremel tool bits.
I have some available. If anyone is interested or wants more information, please contact me by private message.
That's good advise when using any small diameter bits BangsterThey need to be handled with a light touch to avoid breakage.![]()
When you mention length, do you mean the length of the bur (the cutting part) itself? Dental burs are very short. For illustrations and descriptions of them click here.As pointed out they are very brittle and need a lot of care in use.
Mainly because they are so long. If they re-sharpened them to about half the length they would be stronger and more useful.
Ralph B.
The long straight burs are used in what are today called low speed handpieces. ('Low speed' is 20-50,000 RPM, as opposed to high speed handpieces that turn at 300,000 RPM and are water cooled.) Straight burs used to be used in old fashioned dental belt driven handpieces, and are still used on dental lab engines. That's the same type as is used in a Dremel tool. The other type of latch type bur (short, with a notched end) fits right angle (RA) contrangles. A contrangle is a small attachment (that utilizes a shaft and transmission gears) that couples to the end of a straight handpiece allowing it to be used in confined areas at a right angle. When the dentist applies toothpaste to polish your teeth at the end of a professional cleaning, a contrangle that is rubber tipped and made of plastic is used for that. Those are single use and disposable. But the contrangles used to hold a cutting bur are all metal.Depends on the type hand piece they fit. I have gotten long and short. The short ones have a notched end for locking in and all my long ones are smooth shaft for friction grip. For what I've used them for neither has an advantage over the other.
And the price is right....Free..![]()
