Midget invasion
Ken M
Feb 28, 2009
1,289
39
Holiday, FL
Got this beauty today, you've probably seen it. Koma midget. Got it cleaned up. Ordered a bottom block for it today, so hopefully by the end of the week it will be running. It was fully wound, but the escape wheel wouldn't move. Tomorrow the movement. A Kundo midget will be here tomorrow or Wednesday, probably tomorrow.
Reactions: Wayne A
tracerjack
Jun 6, 2016
1,936
312
Lodi, CA
I like the 3 ball pendulum on the Koma midgets, and I like midgets in general since they take up so little space, you can easily find space for more than one. Yours shined up nicely!
KurtinSA
Nov 24, 2014
4,757
338
San Antonio, TX
Eric -
In the catalog cut, Koma calls the clock "Boy". I've seen catalog cuts for other small Komas also called "Boy". Any idea why they were doing this, giving the same name to different clocks?
Kurt
etmb61
Oct 25, 2010
2,909
317
Mascoutah, IL
Koma called all their smallest clocks "Boy" and all their 9" range clocks "Liliput". Those are the names they chose for their product lines. The numbers designate which "Boy" or "Liliput" or standard 12" clock you're looking at.
Eric
Ken M
Feb 28, 2009
1,289
39
Holiday, FL
I don't know, got me stumped too. I got the Kundo running. The book says "15 beats per minute". That ain't right, I got 10.
Wayne A
Sep 24, 2019
809
129
OK,... Somebody please tell me how a mainspring ends up like that.
BOOM thats how. :)
Found them in many pieces too, always thought that it had to break in one spot then as it rapidly expanded there were a few stick/break again spots that happen in that fraction of a second of energy release.
Wayne
Ken M
Feb 28, 2009
1,289
39
Holiday, FL
So I wonder why Kundo decided to reverse the pendulum adjustment, clockwise to increase instead of decrease the rate. My Edgar Henn is like that. Kind of a PITA.
etmb61
Oct 25, 2010
2,909
317
Mascoutah, IL
Schatznut
Sep 26, 2020
570
233
SoCal
Hint: Kundo never made a midget movement - they just cut a notch in the back of their miniature movement to make more room for the top of the pendulum. Space - the final frontier.
etmb61
Oct 25, 2010
2,909
317
Mascoutah, IL
The adjustment mechanism is the same as the larger pendulums. What changed is the shape of the arms that hold the balls, from a relatively straight lever to one with a sharp angle. So now with the same movement of the adjuster the balls come in rather than go out. To keep the adjustment in the same directions they would have needed to replace the screw in the center with a left hand threaded one, creating a separate stock of parts for the different model. Not a good business decision even back then. Much less expensive to just reverse the stamps. I think most households would have only had one 400 day clock (if they had any) so it would not have been a problem.
Eric
Reactions: Ken M
Ken M
Feb 28, 2009
1,289
39
Holiday, FL
My mistake, the Koma says "15 beats per minute" for suspension unit 38A, I'm getting 14 and it's keeping good time.
Ken M
Feb 28, 2009
1,289
39
Holiday, FL
I lied, it was 5 minutes slow. I kept advancing the pendulum until it maxed out, and was still slow. So I went to a .0023". First impression is good, but I've been known to embellish, or lie.
168,853
1,473,375
48,613
johndavidcham
2,955
