Another piece I just found in my grandfathers collection. According to a little note he had with it, it's ca. 1780, 18KT case, 1/4 repeater, with a "special no-over-wind" mechanism. I can confirm those last three things, (at least, it seems to be 18KT, though I'm no expert). It also has a "PA" sponsor's mark, though of course that isn't much help as it's Swiss.
Searching Meynadier brings up essentially no useful information. The only references to such a name I can find are a couple auction listings, one explicitly for a Meynadier a Geneve piece. Then there are a couple references to an "A." and an "Alex" Meynadier, one of which is of a piece in the Met's collection, and then another auction for a "Moynier Meynadier", presumably referring to the same from Bautte & Moynier, which would be around the same time this watch was supposedly made, so I suppose it's a lead. (As a side note, I also found a watch simply marked with "Boutte", is that a possible relation to Bautte?)
(Also, yes, for some god-forsaken reason he put a sticker on the inside of the case, as can be seen in the reflection in the second picture)
