Metal Polish on Pinions
David M.
Jun 12, 2019
30
72
Hi All
Is there a problem using a bit of metal polish as part of pinion "grooming". I find that if I have a pinion that does not clean up well with a file or stone or burnisher that a bit of metal polishing will leave a mirror finish. I then soap and water clean that pinion followed by a burnishing. I'm using "Wizards Metal Renew"
Thanks in advance. I lurk in the shadows here daily.
David
John MacArthur
Feb 13, 2007
392
laplaza.org
Nothing wrong with metal polish. On some of the British grandfathers it might be a little overdo, but the fine French ones , chronometers, regulators, etc.can easily use it. Not sure why you'd burnish after polish.
Johnny
5,293
706
To use polish is fine. The important thing is to remove all traces of the polish so that it doesn't become a grinding paste over time.
David M.
Jun 12, 2019
30
72
Johnny
John
Why? Just thought it would not hurt. This is a hobby----So I make every project last. I'll stop re-burnishing.
You guys are a lifeline
David
wow
Jun 24, 2008
5,675
697
76
Pineville, La. (central La.)
Are we talking about polishing pinions or pivots. I would think getting metal polish out of cut pinions would be tough and lantern pinions terrible. Am I missing something?
David M.
Jun 12, 2019
30
72
Will
Wrong "P" word. Mt bad. Yep. I meant pivots.
Is that still okay then?
David
Mike Phelan
Dec 17, 2003
10,400
142
West Yorkshire, England
Only thing I use metal polish for on a clock is for brass parts, and then only on clocks which were polished originally.
Than I wash and brush it all off afterwards.
Dick Feldman
Sep 1, 2000
2,764
306
Colorado, usa
It would be helpful to think of this microscopically. Polishing compounds universally contain abrasive particles. In precision machine work it is normal to grind metals only if the metals are extremely hard. Softer metals are cut. Think about axles in trucks with metals as hard or harder than normal cutting tools. I assume the reason is that microscopic particles from polishing compounds/grinding wheels are embedded in softer metals, causing an abrasive surface. That would negate any smoothing done by the abrasives and will accelerate wear. I do not believe that simply washing with soap and water or cleaning with an ultrasonic cleaner will remove all of the residual abrasive trapped in the pores of relatively soft metals.
Therefore, I feel using abrasives on pivots or pinions or any other sliding parts in a clock movement is certainly not beneficial.
Polish your silverware, your old car bumper, etc. if you feel you need to see it shine. A proper preparation for the soft metal in pivots is burnishing.
You asked,
Dick
Reactions: Jonas and Altashot
R. Croswell
11,157
1,222
www.greenfieldclockshop.com
Don't be too quick to jump to conclusions about to polish or not to polish. Lots of people do polish pivots and have consistently good outcomes. The key is to remove all the polish and the trick is how to know when it is all removed. We are talking about particles too small to see even with a normal microscope. We have seen here electron microscope images of polished and or burnished pivots with essentially identical smooth surfaces. There was not evidence of imbedded abrasives..... and no detailed explanation of how the parts were cleaned. We hear a lot of theories and speculation of what might or might not happen but personally, I have never seen any proof that abrasive particles become imbedded in steel pivots or that "normal" clock cleaning methods are inadequate to remove them. Of course if you can master the art of burnishing there is no need to polish.
Mike Phelan
Dec 17, 2003
10,400
142
I wasn't really saying not to polish, but that it was really a pointless exercise! We could come back in a hundred years with two identical clocks where one was polished, and the other one not to find the actual outcome ...
R. Croswell
11,157
1,222
......if both clocks received maintenance at the same interval, were oiled with the same oil, subjected to the same environment and so on. Of course if both clocks ran for a hundred years the question of whether abrasive polishing is harmful would be irrelevant and we would all be dead anyway. Just like this or that kind of oil, takes years to demonstrate what works and what does not.
5,293
706
If one wanted to do an experiment like this, comparing just two clocks wouldn't do it. One would have to have two representative groups of clocks, one group polished, one burnished with all other parameters kept equal. Maybe a hundred clocks in each group, or so. This number needs to be large enough to show a statistically significant difference. The magnitude of this difference need to be defined upfront, for example the number of clocks still running after a running time without intervention of 20 years or so, with a difference of 10 clocks considered relevant.
Alas, I'm too old to run this experiment....
JimmyOz
Feb 21, 2008
1,088
278
66
Gold Coast Qld
You better add a 100 with nothing done to the pivots as a control, wonder if the placebo affect would kick in?
Reactions: Uhralt
169,694
1,481,173
49,098
Heresolong
2,965
