Mercury Pendulum
harold bain
40,853
179
73
I am using this mercury pendulum in my IBM model 35. I was wondering if anyone might recognize it and know its origins? It has plated metal jars with threaded caps on both ends. The rod is slightly larger than the 1/4 inch rod on my invar pendulum.
jkfabulos
Aug 21, 2001
967
111
If you can supply detailed photos of the top and bottom frames, adjusting nut and top of rod attachment to the suspension spring I will try to identify it. I have been collecting mercury pendulums for many years and have many identified as to maker.
harold bain
40,853
179
73
JK, I can't get any response from the attach files box right now. If you email me I can send a detailed closeup photo to you of this pendulum
H.Weiland
Feb 4, 2002
199
www.execpc.com
It looks similar to my Self Winding master clock pendulum. The screws that hold the mercury tubes in place seem different. Will check when I get home tonight. It seems to me that I was told by a former employee that S. W. C. C. pendulums came from Seth Thomas.
Hope this is of some interest.
Henry Weiland
harold bain
40,853
179
73
Thanks, Henry. I looked through my Seth Thomas books, and saw nothing similar, but there isn't much in there with mercury pendulums. It has a 4 spoke regulator on top for fine tuning. It is quite accurate. I installed it 3 weeks ago, and I haven't touched it for two weeks now, and it is only out about 1 second.
John Hubby
Senior Administrator Emeritus
NAWCC Star Fellow
NAWCC Life Member
Sep 7, 2000
12,294
241
The Woodlands, TX
Harold, I notice the photos in your message show as "Attached Images" instead of "Attached Thumbnails". They don't open to me either, think you need to check when you upload that the file size is big enough to create a thumbnail.
John Hubby
harold bain
40,853
179
73
John I think I will have to take some fresh pictures, as I ruined these trying to get them small enough to post. They were originally sent to me in an email. Lets see if this one is any better :thumb: Much better!!!
harold bain
40,853
179
73
Richard T.
Apr 7, 2005
5,064
I thought I would post the one on my Self Winding Clock Co. clock. It is somewhat different from the one that Harold posted. Don't know if they made their own or not but it is shown in LY's American Clocks Vol 2 in the SWCC section.
Best,
Richard T.
harold bain
40,853
179
73
Very similar, Richard.
Mine has a fine tuning adjustment on the top of the cylinders that is rated at 1/4 turn equal to one second per month.
Richard T.
Apr 7, 2005
5,064
I have read that some of the SWCC ones and others had the tray above the pendulum bob and a set of small x gram weights to fine tune the rate of the clock. Will have to see if I can find where I read that.
Haven't seen a set of these small weights but would like to:p
Best,
Richard T.
paradise
Jun 24, 2007
100
78
florida
I have a few SWCC mercury pendulums and both are different from the one pictured here. The most obvious difference is the brass base and top. The base is shaped somewhat trapazoid for my lack of a better word, It is widest in the center and tapers down at the ends. That difference alone is enough to rule out IBM.
167,159
1,456,618
87,340
Jerrydodge
