Maximum load on jewel bearings
Discussion in 'Clock Construction' started by dandydude, Feb 1, 2018.
  1. dandydude
    dandydude Registered User
    Nov 30, 2014
    221
    Clockmaker
    India
    Is there something like a maximum load on jewel bearings? I intend using 1.5mm ID olive hole jewels for the escapement pivots. Would an excessive weight (of crutch rod) damage the jewel bearing?
  2. Phil Burman
    Phil Burman Registered User
    Mar 8, 2014
    173
    17
    Suffolk England
    Sapphire has a compressive strength more than 10 times that of steel and of course is extremely hard wearing so I would think not, providing there is no shock loading.
    Do you not mean the pivots for the pallet, if so is this not standard usage?
    Phil
    dandydude likes this.
  3. Allan Wolff
    Allan Wolff Moderator
    Mar 17, 2005
    614
    37
    Tulsa, OK
    I doubt the weight of a crutch rod would be too much. Jewels are used for mainspring barrel arbor bearings in pocket watches which would be much more pressure than anything on a clock escapement.
  4. dandydude
    Nov 30, 2014
    221
    Clockmaker
    India
    Dear Phil,
    I use an asymmetric crutch and its a little heavy to keep it moving with the pendulum. I was a little concerned with the weight. I intend using olive hole ruby bearings. Does ruby have strength similar to sapphire? (I am totally clueless about this)
  5. dandydude
    Nov 30, 2014
    221
    Clockmaker
    India
    Dear Allan,
    Are you aware of how the assembly of the bearing done in clocks?
    Dandydude
  6. gmorse
    gmorse Registered User
    10,530
    1,225
    Retired from Xerox
    Hi dandydude,
    They're both the same material, aluminium oxide, or 'alumina'. They just contain slightly different trace elements which determine the colours.
  7. jhe.1973
    jhe.1973 Registered User
    NAWCC Business
    Feb 12, 2011
    484
    Arizona, USA
    Hi dandydude,
    I agree with Allan that a crutch is unlikely to put enough pressure on a ruby/sapphire bearing to cause any problem.
    This statement may be technically true but in practice it might be misleading.
    Here is a view of some of the jewels that I spun set into their mountings before parting them off from the bar stock while still in the lathe:
    Using the burnisher in the foreground, this is a process that has to be practiced to develop the required 'touch'. Not enough pressure and the jewel remains loose. Too much pressure and the jewel is crushed.
    Because of the extreme hardness of ruby/sapphire the material is also brittle and the wall thickness of the jewels that we are working with makes them somewhat fragile.
  8. John MacArthur
    Feb 13, 2007
    322
    27
    Jewels are plenty "strong" for pallet and crutch pivot bearings - they've been used for those for hundreds of years. As Jim says, they can be fragile if you apply point force, or otherwise bash them. Here are pics of my pallet cock jewels in place.
    Johnny
  9. Phil Burman
    Mar 8, 2014
    173
    17
    Suffolk England
    #9 Phil Burman, Feb 3, 2018
    Hi Jim, it's a bit of an apples and oranges comparison. I think that the applied force is not the same when you press a jewelled bearing into a hole versus the force applied by the weight of the pallet and crutch. When you press a jewel bearing into a hole you will generate tensile as well as compressive forces due to the drag on the side wall of the bearing, which may cause the trailing end to break away. Diamonds are used in hardness testers by pressing them into the material being tested, included hardened steels (copressive force only). In use with a pivot a jewel bearing is only subjected to a relatively small compressive force.
  10. jhe.1973
    NAWCC Business
    Feb 12, 2011
    484
    Arizona, USA
    Hi Phil,
    I feel that the question that was originally asked has been answered for dandydude.
    My use of the word misleading was not intended to suggest that you were misleading anyone. I was concerned that others coming to this thread might get the impression that a person could treat a ruby or sapphire jewel the same as an equivalent steel item.
    When mounting jewels, I do not press them into their holes before spin setting so there is no chance of a tension force being generated.
    So as not to hijack this thread, I decided that I would post details in my own thread that discusses my own regulator movements.
    https://mb.nawcc.org/threads/owner-built-precision-regulator.74057/page-4
  11. dandydude
    Nov 30, 2014
    221
    Clockmaker
    India
    #11 dandydude, Mar 15, 2018
    Dear John,
    Thanks for the images. I wanted to understand how this is done. Is the jewel glued?
    i have attached a sketch to help you understand my question. I have roughly sketched your jewel assembly.
    Why doesn't the jewel come out of the side B?
    Dandy
  12. John MacArthur
    Feb 13, 2007
    322
    27
    Dandy -- It's done like this: The jewel is a snug fit into the chaton (same as bezel), and the small groove around it is burnished over the edge of it with a smooth round-pointed burnisher. Look at the first pic in the #8 post above, and you'll see it
    Jewel setting.jpg Johnny
  13. dandydude
    Nov 30, 2014
    221
    Clockmaker
    India
    Dea
    Dear John,
    Any particular reason for using straight hole jewel? I intend using olive hole jewel for escape wheel. Doesnt olive hole have less friction?
    I also read that straight holes are stronger, so maybe i would use them for the palets like you have... Is it because of better strength than you have used straight hole bearings?
    Regards
    Dandy
  14. John MacArthur
    Feb 13, 2007
    322
    27
    Dandy -- It's because that's the way they come out when I drill and polish them. I'm not sure I could control the shape and size of an olive hole jewel. I make these myself from raw ruby boules, and each one is slightly different. I'll be posting pictures of this sequence during the construction of my next clock, which I will be starting soon. Stay tuned.....
    Johnny
  15. John MacArthur
    Feb 13, 2007
    322
    27
    Dandy, I also suspect that my jewels do have a minute amount of olive shape - the way I polish them they would almost have to, even if it was largely imperceptible.
    Johnny
  16. dandydude
    Nov 30, 2014
    221
    Clockmaker
    India
    Dea
    Dear John,
    Regards
    Dandy
    Oh wow!!! I thought you buy stock ruby bearings ... I didn't know you could drill rubies !!! Thats really amazing
  17. dandydude
    Nov 30, 2014
    221
    Clockmaker
    India
    HI Johnny,
    What size are the ruby holes? I am currently experimenting with 1.5mm ID (for the escapements).
    I have tried miniature ball bearings (which gradually failed), PTFE from Igus and now i am upgrading to rubies...
    I clearly know by experience how ball bearings can fail in escapements now
  18. John MacArthur
    Feb 13, 2007
    322
    27
    Dandy -- My jewels are different sizes - mostly in the 1.25 mm range, to fit the pivots. The front escape jewel is quite a bit larger, over 2 mm I think.
    Johnny
  19. Phil Burman
    Mar 8, 2014
    173
    17
    Suffolk England
    #19 Phil Burman, Mar 18, 2018
    Hi Dandy, I'm interested in what way they fail? I have used them on the escape wheel arbor but not the pallet arbor and after a year it is still running fine.
    Phil
    PS Erwin Sattler use them extensively so there must be a solution
  20. tok-tokkie
    tok-tokkie Registered User
    Nov 25, 2010
    310
    Cape Town, South Africa
    Certainly the Sattler self assemble clock uses ball bearings everywhere with the exception of the pallet arbor. That runs in jewels & Sattler supplies oil for them.
  21. dandydude
    Nov 30, 2014
    221
    Clockmaker
    India
    Dear Phil,
    I have used 2mm ID ball races (Japanese made NMB)... at least 3 sets. The ones used for the palets failed much sooner than the ones of the escape wheel. I even tried using fully ceramic ones.
    They just get a bit rough after a bit of use. Currently my palets are running on PTFE plain dry bearings 1.5mm ID. Escape wheels on ball races (2mm ID). Its been working for a month. I wouldn't be surprised if they fail anytime soon. Thats the pattern i have been observing.
    Regards
    Dandydude
  22. dandydude
    Nov 30, 2014
    221
    Clockmaker
    India
    Hi tok tokkie,
    I had read someplace that bearings are not meant to be run in a jerky fashion. I mean a non-continuous (if there's such a word) circular motion. I don't know if thats the reason for the failure. This is why Iam really trying jewels for both arbors.
    I am also going to try to use endstone in both the arbors (all four pivots)... I have never attempted it... which is why i have so many questions.
    Regards
    Dandy
  23. dandydude
    Nov 30, 2014
    221
    Clockmaker
    India
    Hi Phil,
    I also remember i met this really famous clockmaker one time. He said they remove ball races and clean the balls off any lubricant and put them back. They run it dry. I haven't attempted that. Maybe, thats a way of solving the problem.
    There's one other thing... i use shielded races. That could again be a problem...
    Regards
    Dandydude
  24. dandydude
    Nov 30, 2014
    221
    Clockmaker
    India
    D
    Hello John,
    Is this what they call 'the rubbing method' of setting rubies?
    Regards
    Dandydude
  25. John MacArthur
    Feb 13, 2007
    322
    27
    Hi Dandy -- I would think so.
    Johnny
  26. Jim DuBois
    Jim DuBois Registered User
    NAWCC Member Sponsor
    Jun 14, 2008
    2,558
    421
    Magnolia, TX
    you might want to try Rex Swensen's site, he has done a lot of research on using ball bearings in clocks https://drive.google.com/drive/folders/0B6If277wwdHNeGlYdlkteHJUWXM a great paper on his work, there is more, several folks are having very good success with absolutely dry running ceramic bearings
  27. dandydude
    Nov 30, 2014
    221
    Clockmaker
    India
    Dear Jim,
    Thanks for the link. Quite enlightening.
    Dandydude
