Mauthe won't chime at 7 o'clock
Mountain Man
Aug 23, 2019
22
81
Arizona
My Mauthe grandfather clock chimes correctly on every hour except 7 o'clock. I have the dial off and can see that it clicks and sets up properly on the rack but when it starts to go, the rack hook hangs up and freezes on the first indentation.
bruce linde
ADMIN / MODERATOR
8,868
1,376
oakland, ca.
clockhappy.com
do you mean the hourly strike?
i can't imagine what might be different at 7 from the other hours if it works correctly at 6 and 8.
how about taking a video with your phone, uploading it to youtube, and then copying and pasting the url into a post here to automagically embed the video? that way we could see what's going on.
in the meantime, you might want to start endlessly at the rack and gathering pallet and see if you can spot where it's binding. you probably also want to make sure the rack tail that meets the snail is not binding there.
Mountain Man
Aug 23, 2019
22
81
Arizona
Thanks Bruce, Yes it is the hourly chime. It is a mystery to me also that all the other hours work fine. The video idea is a good one; I am technically challenged but will try to do that. This clock has a cord that you can pull and make it chime. Interestingly, when I do that on the seven o'clock hour it works fine.
46,945
1,996
It might be the gathering pallet that needs a little tweak. That's the part that lifts the rack up while it strikes. The pin might be bent just a tiny bit off straight. Try setting it a fraction closer to the center of the pallet.
Mountain Man
Aug 23, 2019
22
81
Arizona
Wow! Thanks for that. It gave me an idea. I noticed that the pin that drops into the teeth of the rack wasn't dropping all the way down into the "v" of the 7 o'clock position when it was set up for the strike. It was actually sitting almost on top of the 8 o'clock tooth. So I very slightly tweaked the pin on the tail of the rack so that when it rode on the snail it moved it to the correct starting position. The only reason I can think of as to why it was only a problem at 7 is that maybe the 7 position on the snail was worn more than the other positions.
I ran it through all the hours and it works perfectly. Can't tell you how happy I am to have this forum available. You guys are awesome!
Reactions: PatH
46,945
1,996
I'm glad it worked! That's a strange issue :)
Mountain Man
Aug 23, 2019
22
81
Arizona
It is a 1923 clock so that is a lot of wear, but you would think all the positions on the snail would have worn the same.
claussclocks
Mar 14, 2013
916
313
Texas
Shutterbug gave you the same suggestion I was thinking. I have seen this happen a few times. You have to consider the geometry of the rack and pallet. Most racks are curved just a bit and somewhere near the middle the slightest error of a bent pin, bent arbor end, or even a worn bushing can throw off the mesh of the pin to rack. When I have seen this it is usually just about the middle of the strike. I have seen it be 5 as well so that 5-7 range is likely going to be the issue.
DPC
Reactions: Mountain Man
Mountain Man
Aug 23, 2019
22
81
Arizona
Interesting point DPC. I'm happy that tweaking the pin at the end of the rack seems to have done the trick; it has run on it's own now for over 48 hours and all strikes are good . If it happens in the future it's great to have a panel of experts to come to who have been there.
Thanks,
Bob
claussclocks
Mar 14, 2013
916
313
Texas
Thanks,
Bob
Remember! An expert is a former drip under pressure. :D:D
Mountain Man
Aug 23, 2019
22
81
Arizona
"For every expert there is an equal and opposite expert" (Arthur Clarke)
167,090
1,456,040
87,298
Samways
