Mauthe Mess
Discussion in 'Clock Repair' started by wow, Aug 15, 2017.
  1. wow
    wow Registered User
    Jun 24, 2008
    3,779
    215
    Retired Music Minister
    Pineville, La. (central La.)
    Got in this Mauthe yesterday and couldn't believe the punched S2 and C2 pivots. If these had been properly bushed when the repairer punched them, the job would be easy. Now I've got to fill in the missing brass and bush them. Surprisingly, there was only one other bad bushing..T2 (not too bad). How should I fill in the missing plate sections and make them look good? How do you fill in those punched sections of the plate? Need some advise.
    Thanks,
  2. Willie X
    Willie X Registered User
    12,495
    867
    I wouldn't worry to much about the cosmetics. A few well placed bushings will make it all better.
    You could use a Bergeon bushing on the worst one. The new bushings will cover most of that damage and the little damage that is not covered will not affect the soundness of the repair.
  3. BLKBEARD
    BLKBEARD Registered User
    Nov 15, 2016
    759
    24
    HVAC, MECHANIC, CLOCK REPAIRER
    CT
    If your looking for improved cosmetics, you could make your own bushings with an oversized O.D.
    or you could use an oversize off the shelf bushing, & go with a bushing within a bushing.
    Either way will be less noticeable than trying to fill the dimples.
    I think Willie has it right that they wont effect the bushings, but you have the first hand view of the plates.
  4. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    3,762
    279
    watchmaker
    Yes. The bushing hole, especially if a Bergeon bush is used should mostly take out the punch marks. A little chamfering of this hole before you press the bush in and most of it will be gone.
  5. Bruce Alexander
    Sponsor NAWCC Brass Member
    Feb 22, 2010
    6,184
    409
    Check your depth carefully to make sure you haven't lost center. Fortunately all of the punching was mostly on one side.
  6. wow
    wow Registered User
    Jun 24, 2008
    3,779
    215
    Thank you, gentlemen. So sounds like you all would bush first, then clean it up. Not clean it up and then bush. I like the idea of a Bergeron bush. Will try it this morning and let you know.
  7. roughbarked
    Dec 2, 2016
    3,762
    279
    watchmaker
    The importance is find the center and try several bushes against what you are faced with and choose the bush that produces the most pleasing results.
  8. shutterbug
    41,834
    932
    I think any major attempt to make it look better (like making a bigger bushing) would just make it worse for the next guy. I'm with the others, do the best you can with the standard bushings and call it good.
  9. wow
    wow Registered User
    Jun 24, 2008
    3,779
    215
    That's what I did, Shutt, and standard bushings almost covered the punches. Cleaned up area and I think I'll leave it alone. If I start trying to smooth remaining punch holes, it may mess up the bushings. Cosmetics are not as important as good, well-centered bushings.
    Thanks, again, guys. Nice to have help making decisions.
  10. David S
    David S Registered User
    Dec 18, 2011
    7,174
    238
    Brockville, On Canada
    Will, how about a picture of the finished job.
    David
  11. wow
    wow Registered User
    Jun 24, 2008
    3,779
    215
    Here you go, David: 313755.jpg 313756.jpg
    Dave T likes this.
  12. shimmystep
    shimmystep Registered User
    Mar 5, 2012
    4,094
    80
    Cambridge, UK
    Nice job, good outcome.
  13. wow
    wow Registered User
    Jun 24, 2008
    3,779
    215
    Thanks, Shimmy. It chimes and strikes in good order now. Guess that's what counts. Don't like the punch holes, but not too bad.
  14. roughbarked
    Dec 2, 2016
    3,762
    279
    watchmaker
    What it now shows is that though the old repair was done, that you have improved upon it.
  15. wow
    wow Registered User
    Jun 24, 2008
    3,779
    215
    #15 wow, Aug 17, 2017
    Thanks, Rough. Owner will be happy. It belonged to his late father.
