Master Nisshin 400 Day . Modified
Raymond101
Jun 25, 2022
299
72
69
Hi I bought a Master 400 day for 20 bucks.
Yes I know there has been lots about this clock I have read all. After getting it first thing I did was does it atleast work. Yes does keep time No gain 10 minutes an hour.
So every 6 months it would be correct for 30 minutes. Knowing from previous posts and just watching it closely there had to be a serious fault.
Yes it was built cheap but the movement seems to be fairly good quality.
The pendulum is a joke. It's weight 257 grams. And had more wobble than a jelly.
Dismantled and de wobbled the design is bad to horrible. Now the suspension spring was still intact measured as 0.0028 inch.
The top of the suspension bridge had been bent downwards. Putting a weird slope angle on the suspension spring distance.
After a few unsuccessful attempts to put it into beat failed. Left it day to think of another solution.
The bridge is too high. Made the bridge screw slots elongated to allow the bridge to be lowered by 3mm . This would place the fork into the correct position for a positive engagement.
Walla it's now working within adjustable range. Also the brass washer that sits on top of the pendulum for locking I soldered in place so it wouldn't flop around.
I have added my hand drawn cad .
Also the pendulum at max slow position the balls hit the back of the case cover.
Eather I got a reject or the japs really hate US!
20230224_215654.jpg 20230224_213539.jpg 20230224_213510.jpg 20230224_215735.jpg 20230224_213435.jpg
KurtinSA
Nov 24, 2014
5,962
666
San Antonio, TX
I've got several Master clocks. While cheaply made in some ways, I actually thought the movement was pretty good. Likely yours has the previous owners disease.
Kurt
Raymond101
Jun 25, 2022
299
72
69
Kurt
The one I got was new in the original box with the packing. It had the cardboard still underneath the pendulum & instructions paper and key . I think it may have been a sold and returned as the top plate was badly scratched if the handle had been rotated .
It may well have been messed with as the locking bar was off . As not being put on as a separate item with the instruction leaflet.
Ken M
Feb 28, 2009
2,154
238
Holiday, FL
I got one of those locally when I first got back into these things. I didn't have a spring winder at the time, so I just got it running. Ran fine for the first year, then started stopping. Serviced the mainspring a month or so ago and got all the black sludge out of it, now it keeps excellent time without stopping.
Raymond101
Jun 25, 2022
299
72
69
Do you have a photo just out of interest does yours have the same suspension spring @ 0028'' and the solid lead balls only because it just seems a stranger setup .
KurtinSA
Nov 24, 2014
5,962
666
San Antonio, TX
Hmmm...I'd heard from John Hubby that the spring barrel was crimped closed and was "lifetime" oiled. I never touch the main spring.
Kurt
Raymond101
Jun 25, 2022
299
72
69
Kurt
I read about that as well that they were meant to be sealed for life .
BTW I forgot to mention my clock was marked as M1 448 it has the rounded edges.
So I guess it from the 70s
I was wondering if it needed 0032'' spring and was sent out wrong.
KurtinSA
Nov 24, 2014
5,962
666
San Antonio, TX
How does it match up with the repair guide? Somehow I doubt the factory goofed. What does the pendulum weigh?
Kurt
Ken M
Feb 28, 2009
2,154
238
Holiday, FL
Kurt
I remember John saying that too, but I forgot. That probably explains why I had such a hard time getting the cap back on. Anyway, there was black sludge in there.
KurtinSA
Nov 24, 2014
5,962
666
San Antonio, TX
I took John's info to heart. One less main spring to work on was a blessing!
Kurt
Ken M
Feb 28, 2009
2,154
238
Holiday, FL
What kind of oil were they using back in the 60's? Did they have synthetic? Maybe it was an advertising gimmick. Maybe permanent to them back then was the expected life of the clock, 20, 30, 40 years?
KurtinSA
Nov 24, 2014
5,962
666
San Antonio, TX
According to this post by John, they did use synthetic back then. His experience has been good with this and even when he opened a barrel up, things looked fine.
Unless I had no other options to make the clock run, I wouldn't open a barrel because I know I'd never be able to get it right going back together.
Kurt
Wayne A
Sep 24, 2019
1,067
227
Have one of these but the mainspring I never serviced since the edges are rolled over and supposed to have synthetic oil. Kept it running in a closet for year, kept good time if you did not touch it.
Wayne
Ken M
Feb 28, 2009
2,154
238
Holiday, FL
This thing I got was a junk yard dog. Nothing caught my eye as to whether it had been opened up before, but I wasn't looking. Whatever the case, it needed to be service. I didn't have any trouble getting the cap off, a good whack with a fiberglass hammer and it popped out.
Raymond101
Jun 25, 2022
299
72
69
Kurt
I don't have a repair guide. If there is one might be interesting to read .
I wrote the weight of the pendulum above its 257 grams ,4 solid lead balls. That's almost a 1/2 lb. :oops:
I prefer working on brocot clocks.
This clock I just bought it because it was cheap and was in the original box.
It looked good . I forgot the old saying all that glitters Isn't gold / (Brass) .
I have now atleast got it to 1 minute a day . Few more adjustments.
My 160 yr brocot is good for 10 sec/per day. My shnid torsion is good for a minute a month. So I hope to get this within my specs.
Raymond101
Jun 25, 2022
299
72
69
The original instruction leaflet
Raymond
KurtinSA
Nov 24, 2014
5,962
666
San Antonio, TX
257 grams is around 9 oz. No big deal really. Most common Kundo clocks have 7.5-8 oz pendulums. Schatz is typically one of the heaviest with around 12 oz...older Becker clock are also around 12 oz. It's all just part of the design.
Kurt
Raymond101
Jun 25, 2022
299
72
69
Kurt
Thanks, I realized that the mass is proportion to the suspension spring thickness. And it's easier to change the mass rather than changing the suspension spring size . It's now running well 4 Rev per min @ 15 sec per Revaluation.
The main problems we're that the bridge top was bent downwards to compensate for bad positioning of the fork . So lowering the bridge assembly 3mm . As per my cad in about post.
Also the top of the bridge was pressing against the case lid.
I increased the mass 0.5 gram which has brought it in correct adjustment.
Raymond
181,463
1,583,345
54,821
Watchchucker
3,131
Swiss Fake by Kent
Top
