KurtinSA
I've been trolling a nearby Goodwill store and saw this today...I was actually shocked to find anything there. It's by the Nisshindo Watch Co., the Master 400-Day, plate 1461E due to the rounded corners. Previously John had said that these were likely produced in the mid 1960s, not 1950s as the guide says. I took the suspension guard off; there's a key but the shank has fractured from the winding wings...I might be able to reattach some how.
The fork is oddly aligned. Any chance that the suspension spring is supposed to be so twisted?? I suspect not...we've had another recent thread about a severely twisted spring. I also notice some kind of pointer that wraps around the adjuster knob. I can't figure out what that's for other than as a reference to where the adjuster is moved during regulation.
I did some searching for other threads and found where John says that the spring barrel shouldn't be opened...synthetic oil is used and the cover is crimped in place:
https://mb.nawcc.org/showthread.php...aster-standard&p=989154&viewfull=1#post989154
Good to know. But the winding arbor appears to be quite locked up...can't wind or unwind it...plus I don't see an easy way to get to the click to release the power. Manually moving the anchor pin doesn't release the escape wheel, so the whole train appears to be locked. If anyone has some ideas, I'm all ears.
I see where Burkhard posted in the past about a very similar carriage-type clock:
https://mb.nawcc.org/showthread.php?57119-Best-I-could-make-out-of-it
Kurt
Kurt
