"Marked" Pillar and Scroll Clock
Discussion in 'Wood Movement Clocks' started by Sooth, Jun 10, 2018.
  1. Sooth
    Sooth Registered User
    Feb 19, 2005
    3,899
    51
    Cabinetmaker
    Cornwall, Ontario, Canada
    During the recent (and just completed) restoration of a lovely Wadsworth, Lounsbury & Turners wooden works pillar and scroll, I made an interesting discovery. This case appears to bear a maker's stamp pressed into the wood in the top board. I don't know how I missed it for several months while moving the case around, making repairs, and cleaning, but when it came time to wipe-off some hide glue, the stamp was revealed in full detail, and I was quite amazed to see it.
    The stamp is the sort you would typically see as an owner's mark on woodworking tools of the early 1800s, and it's a simple rectangle reading H JUDD.
    The only 2 references regarding a "Judd" that I found are:
    Roberts & Taylor:
    Henry L. Judd, Torrington, 1835, case type "cc" E. Hodges shop, documentation: L, M
    cc = stencilled column & splat, short pendulum (with same variations)
    Palmer:
    Judd, Henry: Wolcottville (Torrington), Conn. n/d. Name on shelf clock paper.
    Both, however, would seem to be dated a bit late for a pillar and scroll case. Are there any other "marked" cases out there? I'd love to know if anyone has any addition information.
    The current photos I have aren't very good, but I will take better ones soon.
  2. Steven Thornberry
    Jan 15, 2004
    22,349
    1,122
    Ne’er do well
    Here and there
    So, Wadsworth, Lounsbury & Turners (WLT) were in business from 1827 to 1829 in Litchfield.
    Henry Judd was born 1805 (per Spittlers and Bailey) and made cases for Erastus Hodges and others in Torrington, where Judd is found ca. 1835. Hodges was active ca. 1825 to 1837 (again per Spittlers and Bailey).
    Litchfield is located SW of Torrington, which, like Litchfield, is in Litchfield County.
    Although Judd is listed as ca. 1835 in Torrington, it is not impossible he was active 8-10 years earlier; so, he could conceivably made cases for WLT.
    Am I too far off base here?
  3. Sooth
    Feb 19, 2005
    3,899
    51
    Cabinetmaker
    No Steven, that seems entirely possible. I just don't have much information about this Henry Judd fellow, so the date of birth does help. I really need to get a copy of the Spittler & Bailey book. I'd still be curious to know if there are other marked cases out there. It was initially hard to see, so it's possible many have overlooked this detail.
  4. Steven Thornberry
    Jan 15, 2004
    22,349
    1,122
    Ne’er do well
    Here and there
    Yes, it would be interesting to see whether other such clocks are out there. Otherwise, information on Henry Judd may have to come by channeling his spirit through a competent medium. I found one mention of him in a 1952 issue of the Bulletin, a bare mention providing no other information than what we can glean elsewhere.
  5. rmarkowitz1_cee4a1
    Nov 26, 2009
    5,283
    Hi Sooth.
    My recollection of Henry L. Judd (if that is in fact who die stamped your P&S case) is as a case maker for Hodges and North. He took their Torrington-type movements in trade for cases. He then cased the movements generally in 1/4 column and splat "transition" clocks.
    SO, that lead me to my go to reference on all things Torrington, Lanzo and Brown.
    Page 100 of that reference has a nice little summary about him.
    Also see Chris Bailey's Bulletin article:
    http://docs.nawcc.org/Bulletins/1970/articles/1972/161/161_803c.pdf
    Scroll down to page 825-827 of that article.
    Apparently HJ resided in Litchfield, CT until his marriage to Hannah Beach in 1830 shortly after which the couple relocated to Torrington, CT.. Hannah, by the way, painted tablets for North and Hodges.
    So, it is conceivable that he made cases for WL&T of Litchfield before moving to Torrington??
    Unfortunately, my Wadsworth and Turner P&S is not easily accessible for an inspection. My recollection is that it is not die stamped like yours.
    RM
  6. Sooth
    Feb 19, 2005
    3,899
    51
    Cabinetmaker
    Thanks so much for the additional info, RM. It would be fun to give your PS clock a closer look once you can get to it.
  7. rmarkowitz1_cee4a1
    Nov 26, 2009
    5,283
    #7 rmarkowitz1_cee4a1, Jun 12, 2018
    Your welcome.
    My interest is piqued.
    Hopefully will get to it in the coming months?
    Or I may just have to conduct a séance in my dining room.
    Hodges and North also made pillar and scroll clocks. HJ made cases for them. It would be interesting to know if any of their pillar and scroll clocks is so marked as well? That would be interesting to learn and might strengthen the assumption that the H. Judd die stamp on you case is the mark of that Henry Judd?? Just a thought.
    RM
  8. Sooth
    Feb 19, 2005
    3,899
    51
    Cabinetmaker
    Before:
    After:
    PatH likes this.
  9. Sooth
    Feb 19, 2005
    3,899
    51
    Cabinetmaker
  10. Jim DuBois
    Jim DuBois Registered User
    Gibbs Literary Award NAWCC Member Sponsor
    Jun 14, 2008
    2,957
    650
    Magnolia, TX
    Nice work on saving this clock. The finding of the stamped casemakers signature is certainly new to P&S cases in my experience. While it is not uncommon for seatboards to be stamped in a number of tall clocks, mantle clocks bearing stamps are virtually unknown, and even more unlikely is stamping on what is evidently a fairly "late" pillar and scroll, 1827-1828 and is supported by the very early working times of the case maker, perhaps working as an "apprentice?" as said above.
  11. jimkatzin
    jimkatzin Registered User
    NAWCC Life Member NAWCC Member
    Jan 3, 2003
    21
    Hello Sooth,
    Interesting find. I looked at five of my W, L, & T pillar and scrolls last night, and I did not find the Judd stamp on any of them, but I did not do a very thorough inspection. Your dial does not look like any of my W,L&T dials, but it would help to confirm that with a picture of the back of the dial. Also, do you have any shots of the movement?
  12. rmarkowitz1_cee4a1
    Nov 26, 2009
    5,283
    Well, I finally plowed through the stuff and looked at the top of my Wadsworth and Turner P&S. Only able to look at the top board as it is still rather buried as you can see:
    Here are some pix of the top board:
    Much of it "stock" so the price tags. One of these days will impose order upon my dining room.
    No "H JUDD" diestamp at least on the top board.
    Pardon my dust. As I say, Hazel quit.
    An interesting find.
    RM
  13. PatH
    PatH Registered User
    NAWCC Fellow NAWCC Member
    Dec 5, 2014
    1,838
    1,303
    Female
    Texas
    Not dust, patina. At least that's what I tell visitors to our house. I'd much rather learn about clocks than dust them! :D
