Making a hang on the wall wood clock
Discussion in 'Wood Movement Clocks' started by Tinker Dwight, Jul 28, 2017.
  1. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    How many have ever thought it would be fun to cut out
    a ply wood, large wheel, hang on the wall type clock. I know
    I have.
    Still the thought of cutting out a number of properly messing
    wheels and possible pinions seems like a task beyond what
    I'd like to try.
    Well I just saw a tool called the "Shaper hand held router".
    Once the plans where drawn, it would be a easy project to
    turn out perfect wheels.
  2. leeinv66
    leeinv66 Super Moderator
    NAWCC Member Donor
    Mar 31, 2005
    8,032
    12
    Industry Specialist
    Launceston Tasmania
    You had me right up until I checked into the price Tinker. :whistle: But yes, that would be a great piece of equipment to use. I have a plunge router, but most times I use it, I just make a mess.
  3. Tinker Dwight
    13,680
    It is a new product and under patents but I do think the price will eventually
    drop. It is really a cool tool though. One wonders if someone might setup some type
    of rental system. I don't think I need to own one but I'd love to use one for a
    project I have in mind.
  4. Jim DuBois
    Jim DuBois Registered User
    NAWCC Member Donor
    Jun 14, 2008
    1,270
    12
    Itinerate clock purveyor and amateur restorer
    Magnolia, TX
    While this is an interesting product, I would not try to use it to make clock gears/wheels/pinions and the like. Why? It is completely dependent upon hand to eye coordination as a start. That is fine for some work, but when you really do need precise control, such as making clock gears, this machine would get you "close." A 4 axis cnc router (x,y,& z plus rotary) can be made for substantially less money and be made a lot more precise...if you can fabricate some fairly simple machines, put together a simple controller, and grab a very old PC that can usually be had for $20 +/- . And for purposes of cutting large wood gears by routing a 3 axis CNC machine will do nicely
  5. Tinker Dwight
    13,680
    Actually. it makes things to much better controlled than
    you believe. I played with one at the maker faire.
    There is no fine hand eye coordination required. As long
    as you can follow a line within about an inch, the router
    corrects for you.
    I made the second piece of puzzle to match one that some
    one else made. They fit so closely that you could just see
    a tiny amount of light between them.
    I think you missed the important part. You just keep the bit
    within the circle and the router does the rest.
    The main advantage is that it is portable, not like a table mounted
    CNC.
  6. MartinM
    MartinM Registered User
    Jun 24, 2011
    2,333
    14
    El Dorado, CA
    Such a tool used on marine grade plywood would surely produce a workable result.
Similar Threads - Making hang wall Forum Date
SWISS BUCO BAUMANN WOOD WEIGHT DRIVEN WALL CLOCK Wood Movement Clocks Sunday at 6:01 AM
Damm and Wolff large wooden movement wall clock with astrolabe Wood Movement Clocks Dec 12, 2015
Charles Alvah Smith wall timepiece needs help... Wood Movement Clocks Jul 28, 2014
making wooden gear movement Wood Movement Clocks Jan 28, 2012
