This mark has come up here before (you can search for the old threads). As far as I know it has not been reliably identified. This is often the case with these French movements - sometimes the mark is that of the finisseur, but not always.
Later: Just did a quick search and found a Mougin movement which also had the Ch. Vcne. stamp. Looks as if that might be the finisseur or possibly a wholesaler since it is thought that Mougin bought in at least some of the movements stamped with his name.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
