Makers mark
Discussion in 'General Clock Discussions' started by shimmystep, May 1, 2013.
  1. shimmystep
    shimmystep Registered User
    Mar 5, 2012
    4,097
    81
    Cambridge, UK
    I think I've seen this makers mark M.B discussed before but I can't find the thread with the search engine, MB tends to bring up discussions around the Message Board.
    If I remember rightly, I don't think there was a definitive answer, but I may be wrong.
    Quarter striking movement; does the arrangement on the hour rack tail give anyone clues as to the maker? Any ideas? TIA
  2. soaringjoy
    soaringjoy Registered User
    Feb 12, 2009
    7,238
    23
    Oops. Usually "MB" in one form or another is associated with Matthias Bäuerle, so that's
    the easy part.
    The tricky part is, that I haven't seen this particular M.B. in an oval mark before and there
    are of course, several more listings on M.B., some of them "unknown".
    A Max Becker, Berlin, a wholesaler, also supposedly used it, but there's nothing to compare with afaik.
    However, it might well be, that the movement itself really was made by Bäuerle...
    I don't know this time and have to pass it on.
  3. shimmystep
    Mar 5, 2012
    4,097
    81
    Cambridge, UK
    Thanks Jurgen. I saw M Bauerle on Andreas's site, but as you say, it doesn't appear in this form. It's a good quality movement. Plate and pin on the rack tail is unusual I thought.
  4. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    162
    deceased
    I recall repairing a nice British (I assumed) bracket clock with a movement with this stamp many years ago. Wasn't able to find a maker at that time. I suppose it could have been the sellers trademark and not the maker.
  5. Tony10Clocks
    Tony10Clocks Registered User
    Aug 10, 2010
    1,641
    Northant's
    It has some characteristics to Winterhalder & Hofmeier
  6. shimmystep
    Mar 5, 2012
    4,097
    81
    Cambridge, UK
    Interesting you thought it was British Harold, could be. My first impression was German. It does come from an oversized large bracket clock case, I have just been given the movement to give a service. I'll get a pic of the case when it comes back from the cabinet maker.
    What characteristics do you think TB?
  7. harold bain
    40,850
    162
    deceased
    I hadn't as much experience at the time, and it could have been a W&H movement. If I recall correctly it had nested bells on high. This was about a dozen years ago, before I could have posted it here on the message board.
  8. Tony10Clocks
    Aug 10, 2010
    1,641
    Northant's
    On the back it has the same type of crutch, similar suspension cock, the same type of washers on the back plate ( although that doesn't mean anything ). On the front the snail is held on by two screws, the rack is similar, thick plates thick rack and thick snail. I'm probably totally wrong, just an observation
  9. soaringjoy
    Feb 12, 2009
    7,238
    23
    W & H for one, was a company that definately built English influenced movement types, while the
    other companies in Baden mainly followed the French traditions.
    For that, W & H movements and cases are very British, indeed. ;)
  10. shimmystep
    Mar 5, 2012
    4,097
    81
    Cambridge, UK
    They are fair observations indeed TB
  11. shimmystep
    Mar 5, 2012
    4,097
    81
    Cambridge, UK
    I now have the case (first time I'd seen it) and have fitted the movement. Prompt any further thoughts? It stands 18in tall, and looks rather British. The keen eye will spot the Hermle minute hand replacement
  12. soaringjoy
    Feb 12, 2009
    7,238
    23
    A neat clock, Shimmy, but, alas, no match.
    Although there is a rule of thumb: Roman numerals = fancy hands / Arabic numerals = plain hands,
    there were wide variations and especially W&H often used the plain, spear shaped hands on those dials,
    as well as the fancy ones. I suppose, nobody will note your replacement on first or second sight. :)
  13. shimmystep
    Mar 5, 2012
    4,097
    81
    Cambridge, UK
    Thanks for the post and info Jurgen. I may drop the NAWCC library a line re the M.B mark, given it has appeared a few times on the MB as unknown.
  14. Albra
    Albra Registered User
    Oct 17, 2006
    1,311
    7
    Greetings shimmystep
    I suspect that this MB logo belonged to wholesaler Max Busse in Berlin. According the "Lexikon" wholesaler Max Busse was founded in 1884 and was still active in 1940. And yes, the movement might be a M. Bäuerle. And of cours we know movements of M. Bäuerle with logos of wholesalers and retailers.
    As said just a guess, but it could fit.
    regards Albra
  15. soaringjoy
    Feb 12, 2009
    7,238
    23
    Max Busse. Yes, I would second that, Albra! ;)
  16. shimmystep
    Mar 5, 2012
    4,097
    81
    Cambridge, UK
    Thank you Albra. Interesting. I had a look on Andreas's site for Busse's mark which came up with this
    ...registered mark 1922, their earlier marks are not listed.
  17. soaringjoy
    Feb 12, 2009
    7,238
    23
    For the records, note the differences - or similarities, whatever you like. :D
    And Max Becker, from a 1904 address book.
  18. Albra
    Oct 17, 2006
    1,311
    7
    Little deviations between a protected trademark and logo on a movement are very common.
    As we know several very old and trademarks of Matthias Bäuerle, I think that this MB is not by him but by a customer. And when customers come with their own imprint in the first place wholesalers considered. Therefore, my guess is Max Busse, Berlin. But we cannot prove.
    albra
  19. shimmystep
    Mar 5, 2012
    4,097
    81
    Cambridge, UK
    Thank you once again for your input and knowledge Albra, very much appreciated
  20. HowardHorology
    HowardHorology Registered User
    Mar 11, 2019
    47
    11
    Collector
    East Tennessee
    It seems I have just bought a clock with the M.B. in an oval mark which is a mystery for some.
    More photos here:My First Clock
