Here is a old Vienna picked up off FB in the last week or so. I have tried to ID by rummaging through the archives, but had no luck. Here is what I know....clock is 48” tall, 15” wide and 6” deep. The movement is key hole mount. Dial is 7.5” across. There is a 4 digit number stamp on to each of the plates and on the back side of the dial plate. However there is a five digit number on the mount for the movement.
The clock is shown as bought. The case needs minor repairs. I will mention in passing that in my looking for info to help identify this clock make, I found a clock listed on Ebay that had an almost identical case. The clock was a GR single weight clock. At a glance the only difference I saw in the two cases was the GR time only had a true top finial, where mine is cut to shape from a single piece of wood.
Clock keeps excellent time. I look forward to repairing and moving it in where it can be seen with other clocks. Any help appreciated.
