Make your own finials
Discussion in '400-Day & Atmos' started by etmb61, Jan 8, 2020.
  1. etmb61
    etmb61 Registered User
    Oct 25, 2010
    2,450
    159
    Retired Avionics Technician
    Mascoutah, IL
    #1 etmb61, Jan 8, 2020
    So many of my torsion clocks are missing their crowns and finials I decided to see if I could make some of these myself. This is just a test until I can get some proper sized stock. I also need to make some different profiled tools but this is the idea.
    What do you think?
    Eric
    Dave T likes this.
  2. tracerjack
    tracerjack Registered User
    Jun 6, 2016
    1,000
    101
    Female
    Lodi, CA
    I think you’ll end up with some very nice finials. Keep us posted on your progress.
  3. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    Making more scrap but getting closer.
    I should probably measure my sample and draw a picture for next time.
    Eric
  4. MartinM
    MartinM Registered User
    Jun 24, 2011
    3,039
    95
    El Dorado, CA
    Looking good, Eric.
    What's your process?
    The only time I've attempted this kind of thing was for pendulum bobs on "baseball" clocks.
    As I had several that didn't have their pendulum, I decided to get some 3/8 aluminum round stock and grind a fully profiled turning tool. It took a while to get it to represent the original faithfully, but, in the end, it became a quick process to produce them in bulk.
    Drill the center hole about an inch deep, Face the end from he last cut and then position and hog down on the tool till it completed the profile and (hopefully) parted the finished part.
  5. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    I'm making a set of narrow form tools ground from HSS tool blanks. My little Sherline doesn't seem to like the load of a single tool without a lot of howling. Also I thought I could reuse them for different shaped finials. So far I have one for the hemisphere section, one for the tip, and a small radius for the necked areas. I still need to make another for the base. The worst part for me right now is I only have one tool holder.
    The sample is from and early Hauck clock.
    Eric
  6. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    Test 3.
    After this cut I got a bit excited and forgot to finish it before I cut it off. Oops.
    Not quite there yet but getting close.
    Eric
  7. shutterbug
    42,712
    1,111
    Nice job, Eric! Thanks for the pictures! It's close enough that no one would notice the difference when mounted except you :)
  8. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    3,514
    125
    Aerospace Engineer (Ret.)
    San Antonio, TX
    So, I take it you mount the original off to the side and then use your various cutters to shape the blank, all the while looking back and forth at the original.
    What shutterbug said...very nice!
    Kurt
  9. daveR
    daveR Registered User
    Sep 10, 2008
    285
    hospital storeman
    melbourne, Australia
    Nice job Eric, you may have re-inspredme to try.I have a Hauck wirh only its central finial, the other two are gone with the pieces of one still in one hole.
    One question, are the finials pushed in or threaded or both ? I have never been game enough to find out for fear of breaking them, especially if threaded !
    David
  10. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    Well I have to justify all I'm spending on machine tools so I'm making stuff.
    The Hauck clock the sample finial is from is number 2437. These are right hand threaded.
    I have a later Hauck clock number 17377 that I had to fix a broken off finial. It's finials are left hand threaded!
    I haven't encountered any pre-war clocks that had pressed in finials.
    Eric
  11. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    I put the original there just for the pictures after I made the cuts. I did all the checking and measuring when I changed tools.
    Eric
  12. daveR
    Sep 10, 2008
    285
    hospital storeman
    Funny though how,once you have found a use for, and used the tool you felt you "had to justify" you end up finding lots of other uses for it !
    Thanks for that interesting info on the left and right hand threads. Of that I certainly had no idea.
    David
  13. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    The finials need someplace to go...
    This is too much like work! Mill, jeweler's saw, needle files, dremel tool, and sand paper to get to this stage.
    Eric
    Harry Hopkins and Wayne A like this.
  14. shutterbug
    42,712
    1,111
    Lots of work to be sure! Looks great though!
    etmb61 likes this.
  15. Peter W
    Peter W Registered User
    Nov 23, 2017
    146
    11
    Very nice work. I made the crown and had finials turned for this Philip Hauke miniature. Mun Chor-Weng kindly photographed his identical model straight on from which I could make a hairline outline drawing. Printed drawing and stuck the paper on brass then filed and dremelled to shape. I found the circular tube paper sander the most useful tool. Your finials are really good, Eric, better than mine. Well done !
    etmb61 likes this.
  16. Harry Hopkins
    Harry Hopkins Registered User
    Nov 16, 2011
    546
    Retired Instrument Technician
    Mason, IL
    Excellent job Eric! Lots of patience involved especially in making the form tools. I made a finial a few years ago but I did it freehand with a graver... Mine looks pretty good from across the room whereas yours looks good with a close-up.
    etmb61 likes this.
  17. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    Thanks for the comments! Well I finally made one I'm happy with (meaning I didn't screw up too badly). I keep intending to read the hand wheels and figure out the settings, but then I just plunge the tools in until it looks right.
    I think it looks good with the originals. Not quite exact but close enough for me.
    Eric
  18. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    Almost ready for the clock!
    Eric
    Dave T and Wayne A like this.
  19. Les Sanders
    Les Sanders Registered User
    Apr 3, 2010
    740
    23
    Clock Repairman
    Sahuarita Arizona
    My hat is off to you excellent work.
  20. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    On the clock.
    Eric
    John Hubby and Harry Hopkins like this.
  21. John Hubby
    John Hubby Senior Administrator Emeritus
    Sep 7, 2000
    12,274
    213
    The Woodlands, TX
    Great job, Eric!! Congratulations. :emoji_medal::emoji_medal::emoji_medal:
  22. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    Here is a set I'm making for a Becker clock.
    Original on top.
    Original on right. I started on the mounting end (bottom) with this one and it went a lot easier. Didn't quite get the top right. The source clock doesn't have any two finials that match so it would fit right in.
    Eric
  23. whatgoesaround
    whatgoesaround Registered User
    Jan 22, 2008
    427
    21
    science teacher
    south carolina
    Well done. You could start selling parts on the side. I would bet most of us on here has some clock needing something.
  24. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    Here is the near finished part in front of the original:
    Still needs polishing up and the mounting hole(s).
    Eric
    Wayne A likes this.
  25. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    I finally finished that Becker pediment, shown here with the original,
    and on the clock.
    Still need to polish it up before I send it off.
    Eric
    Dave T likes this.
  26. KurtinSA
    Nov 24, 2014
    3,514
    125
    San Antonio, TX
    Nice work, Eric! I recently purchased some Becker-looking finials from The Horolovar Store. They are cast items so there's a bit of a nub on one side that I needed to grind off. I bought the set of three (~$20) as one of my Beckers doesn't have the two finials that push into the holes on top of the movement support columns. Probably the best I was going to do...doubt I could ever do something like you've done.
    Kurt
  27. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    Thanks Kurt. Actually the finals themselves are the easy part because they're done on the lathe. Once you figure out the method you can knock them out. The crown however is mostly hand work.
    I looked at those cast finials but they are all only one style from one clock brand. I don't consider them a suitable replacement. If I need to replace something I like stuff that's at least made in a similar way to the originals. All the years I spent fixing aircraft has made me a little obsessive.
    Eric
  28. tracerjack
    Jun 6, 2016
    1,000
    101
    Female
    Lodi, CA
    To me, a missing finial is like a missing front tooth. Replicating those parts was a lot of work for you I am sure, but certainly worth the effort to see a beautiful clock with all it parts.
  29. FDelGreco
    FDelGreco Registered User
    NAWCC Star Fellow Sponsor NAWCC Diamond Member
    Aug 28, 2000
    1,967
    81
    Retired chemical engineer
    Novelty, OH
    You've inspired me to make a replacement finial for my ca. 1690 English lantern clock. At some point in its history, the finial was sawed off, probably to get extra height (longer running time) in a low ceiling house. I'll have to drill the top and make a replacement. The only problem might be that 17th century brass is a slightly different color than more modern brass.
    Frank
  30. Rockin Ronnie
    Rockin Ronnie Registered User
    Nov 18, 2012
    1,562
    114
    retired educator
    Greenfield, Nova Scotia
    Impressive work.
    Ron
    etmb61 likes this.
  31. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    Hi Frank,
    I would think the finial would have been a casting as well, as opposed to the mill stock I've been using. It could be a fun challenge.
    Eric
  32. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    I agree. I've passed on buying some of clocks because they were missing the decorative parts. Now I wish I had them.
    Eric
  33. etmb61
    Oct 25, 2010
    2,450
    159
    Mascoutah, IL
    Here is some more of my process for your inspiration...
    Blanks were cut from C360 bar stock by hand, CA glued together, milled to their rough size and shape, and then separated with a torch. The finished crown was all hand work with a jeweler's saw, files, sand paper, and some polishing. I managed to cut this one out without breaking a saw blade so I must be improving.
    Here it is with an original:
    Eric
    pahel likes this.
