Most visitors online was 1990 , on 7 Feb 2022
This may sound goofy but I have heard of people putting rags in the tubes to muffle the tone. Take a small mirror and try to look in the tubes. Chris.
It would be good to know what brand movement has been used and how old the clock is.
So far we know that the case was made by Sligh and that it is a recent acquisition.
Adjustment may not be enough to solve your problem.
Very seldom are functioning clocks offered for sale/gift, etc.
It is human nature for people to keep clocks till they do not work properly.
The clock movement may need some "real" repair.
How about some detailed pictures of the movement, chime drum, hammer assemblies, etc.
Dick
Clock was from estate of a ‘clock guy.’ He had three kids, bequeathed them each a grandfather clock, and they are selling the two ‘extras’
Clock is sligh 1980s kienenger or hermle. Seems to work well otherwise, perfect time, at least as good as my iPhone.
Will post pictures, thanks
The tension screw wont reposition hammer from left to right. I assume that is the screw immediately below it. Will the tension screw affect the impact of the hammer on the tube? Does access to these screws require disassembly of part of the movement?Yours has two adjustments on each hammer. One is at the end of the string to adjust the distance of the hammer from the tube. The other is at the bottom of the hammer tail and is the spring/tail tension adjustment. The hammer should hit as near the center of the tube as possible to get the loudest and most resonant sound
The tension screw will affect the impact some. You do not need to disassemble to adjust. Can you reach those screws? Finger adjustment is all that is needed. Some cases have removable top panels that allows you to reach the adjustments from the top.The tension screw wont reposition hammer from left to right. I assume that is the screw immediately below it. Will the tension screw affect the impact of the hammer on the tube? Does access to these screws require disassembly of part of the movement?
Willie, I didn’t know that. I’ve always adjusted them if needed. Why not?The hammer tension screws are not supposed to be adjusted ...
I don't think you are talking about the same thing. The adjustable top screws are for hammer adjustments. The bottom ones are for tension, and usually don't need adjusting.
The tension adjustment is a factory adjusted preload. Just the right load to make for good hammer action with no chance of stalling.
If the drawback is good and there is nothing binding, the only answer for a louder chime will be better hammer material, as already mentioned by Bruce L.
The tubes are a bit high. The hammer should hit each tube at the very edge.
Here isa video that hopefully gives you more information. The hammer strike is about - half inch below the edge of the tube, entirely on the cylinder part. The tubes are held in place by metal hooks. I can create a string loop to lower the cylinder so that the hammer strikes the edge, if that is optimal. Thoughts?
View attachment IMG_5536.MOV
file:///var/mobile/Library/SMS/Attachments/df/15/5788A0C1-751E-4192-9307-3C3FEEB84C25/IMG_5533.MOV
The tubes are hanging from wire clips. The movement I have is The kienenger, not urgos with strings, I could suspend each tube with a loop of string from the frame hook to the wire clip. Would this enhance the sound.?Tubular bells were traditionally hung on strings but a quick look at a modern Kieninger tube chimer shows metal hooks holding the tubes up instead. Is this what your complete movement looks like?
The tubes
1980's Urgos with tubes hung on strings instead of metal hooks. It pays to put the extra effort in.
Thank you for your instructive comments. It is interesting that the ‘orchestral’ chimes that I seen in videos all have a capped or sealed end. The Herschede tubes in the video are also capped. The ones in my clock are open on both ends. Obviously the sounds must be different.You can try using strings but knowing this particular movement outline used clips to hold the tubes up, it's debatable how much it may improve the sound. Newer tubular bell chime outlines only give so much room for improvement, it'll never be the same as an American Herschede or Jacques tubes set. German tubes don't always have the large caps that old American tubes had and that also affects the sound. Then we have the metal composition of the tubes, thickness of the tubes' inner walls, cap shape and diameter of the tubes. Tubes are normally struck on or just below the cap and this varied with so many different outlines. There are so many factors that result in different sound quality but this is largely overlooked since most of the documented repairs on this forum do not pertain to chimes.
I uphold that Herschede's tubes tend to give the deepest, most resonant voice of all tubular bells used on clocks, owing to their customary bellmetal alloy and nickel-cadmium plating. Their later clocks made from 1968 to 1984 had a neat 'eyehook' hanger which allowed the tubes to resonate much longer. A real bright spot in the modern dark age.
Herschede 9 tube No. 120
This is a video of the workings of a Herschede 9 Tube Grandfather clock. This is available for sale at Hicks' Clock Shoppe in New Holland, PA. The clock a ...www.youtube.com
