Most visitors online was 1660 , on 12 Dec 2020
As I catched from some russian videos you should just gently pull the bezel off (still no video with removing itself - sorry). Normally you should not bent those 3 rivets before you remove the bezel. Using some plastic sharp things as levers applying them in the points where those 3 rivets are and around pull bezel out - gently, carefully!!!. It is not glued, just firmly fixed on the plastic(?) round. Somehow like that. Hope this will help.
Thanks Alex. I have not attempted any further disassembly as I have become busy with other clocks. I am hoping to hear from someone who has mastered a disassembly of this clock. Rod.Rod, I understand Russian quite well)) and I can translate for you but there not much more then that I have already tryed to mention in my previous message. Still if you would like we can discuss it by voice and I will translate each word.
I still not fully sure if that guy on video I shared to you give the best advice, but I did not find anything better in "Russian internet" yet.
The same as the one I have. Mine has a blue dial. Any luck yet getting your clock apart?
Hi Kevin. I have not tried again as I too have been busy with other projects. Rod.No Rod, i have not gone back to it. Have a few things on the go.
Thanks for the reply. I will let you know how I make out. Rod.The bezel is simply pressed. From the back pry it with small screwdriver - very simple...
Thanks, Kevin. I still have yet to try the last recommended removal of the bezel. Good luck with yours. Rod.i just looked at mine and no its not like this one.
I just tried prying the bezel off and it came off very easily. Thanks for your help.Thanks, Kevin. I still have yet to try the last recommended removal of the bezel. Good luck with yours. Rod.
Thanks for the help. It came off as you said. Rod.Thanks for the reply. I will let you know how I make out. Rod.
It was easy!! The movement is cleaned and needed i bushing. Works well. Rod.Thanks for the reply. I will let you know how I make out. Rod.
