lmester
I recently repaired a Gilbert time and strike movement. The clock would run but the hands didn't move. I found that it had a cracked cannon pinion. After making a bushing for the pinion, I cleaned all of the parts finishing with the mainsprings.
The clock has loop end mainsprings. I cleaned and lubed the mainsprings and finished with winding them and replacing the mainspring C clamps. With both springs done & sitting on my workbench I took off my gloves and put the spring winder away. I then picked up the springs and took them over to my work table and set them down.
BOING!!! Instantly one spring was jumping around on the floor and blood was dripping from a nasty cut on my middle finger! One of the clamps came loose. I used a band aid to fix the finger and then checked for clock damage. The spring & wheel were undamaged. I cleaned and lubed the spring again and put the C clamp back on.
This time I jiggled the spring around and tapped it on the workbench a few times BEFORE I removed my gloves.
When possible I make sure that the clamp is centered on the spring. Sometimes it needs to be at one or the other edge because of interference with parts in the movement. In this case it was centered on the spring. I have no idea why it slipped off.
Has anyone else had a mainspring come loose several minutes after it was cleaned and rewound?
I did get a little chuckle from this. With a band aid wrapped tightly around the joint on my middle finger, I was unable to bend the finger very far. So, while assembling the movement, I was also giving it the finger.
