Mainspring Replacement Seth Thomas
Discussion in 'Clock Repair' started by dalesr, Dec 3, 2013.
  1. dalesr
    dalesr Registered User
    Jan 4, 2009
    225
    New Jersey
    I have a Seth Thomas Movement A400-000 that needs a Time Mainspring. I know that the Hermle Replacement movement for the A400-000 is Hermle 350-020 movement. Can I use the replacement mainspring for the 350-020 movement for my A400-000 movement? The A400-000 Time barrel is stamped with 8E and the dimensions of the barrel are shown below. I do not know the inner diameter of the Time Barrel on the 350-020 movement so I cannot compare inner barrel diameters.
    A400-000 movement
    Time Barrel Stamped "8E"
    38 mm barrel inner diameter
    10 mm arbor diameter
    Old mainspring 45/64, 42 in length, and .014
    43/64 width
    47 1/2 length
    .0165 strength
  2. shutterbug
    41,062
    779
    That's probably a question for Mark Butterworth. I know some of the replacement movements require a weight change, so I would be suspicious of switching out springs.
