Mainspring Extraction
John Rausch
Mar 16, 2015
125
Bradenton, FL
Here's a little poll... what's your favorite way of (safely) extracting a new spring from the baling wire retainer? (specifically a hole-end spring).
bruce linde
10,370
2,123
oakland, ca.
clockhappy.com
first of all, that retaining clip should be in the middle of the mainspring and not against one edge.... if you were to drop that thing it could extract itself before you know it! :)
i would use my spring winder.... but if you don't have one, you could always go for the method described in the first sentence. :)
Reactions: Willie X
Jrfixer
Oct 26, 2021
41
19
57
Like RC said, with gloves and glasses on and a good grip on a clean bench, cut the wire and slowly let it unwind.
Then wipe it down clean of all shipping oil. Re oil with your favorite variety and wind it up on your main spring winder and install :)
With Band saw blades I use a different technique ;)
Reactions: John Rausch
John Rausch
Mar 16, 2015
125
Bradenton, FL
I have a spring winder that has worked well with loop-end springs secured like this, but catching the hole-end looks a little more fraught with "excitement".
Jrfixer
Oct 26, 2021
41
19
57
You need to add a hook with a 90 degree bend or perpendicular to the spring and not parallel like the loop end spring.
Wimberleytech
Jan 27, 2022
46
67
For a more controlled release, how about using a hose clamp. Screw it down tight, cut the wire, slowly unscrew the clamp. If the range of a single clamp is not good enough, have a second larger one to use once the first one gets to end of travel.
Never tried this...just now thought of it.
R. Croswell
11,880
1,820
www.greenfieldclockshop.com
You say, "how about using a hose clamp ...", is it safe to assume that this is just a suggestion and not something you have actually used? I see several potential problems; you could only control a bit less than half or the width of the spring while the wire is in place, a hose clamp large enough to contain a new spring may be hard to find, as the spring expands it may want to spill out of the hose clamp before fully expanded. Grip and snip will take about 2 seconds, will take a lot longer futzing around with a hose clamp(s).
I don't think anyone mentioned the towel method. Wrap the spring in a heavy towel, clip the wire.
I use a full-face shield when working with a "loaded spring" that could "go off" unexpectedly - in my hand or in my spring winder.
Reactions: Jrfixer
Swanicyouth
Nov 10, 2019
354
100
49
I do it the way I was taught by the Victrola people. Those things have main springs with more power & I own a few. Wrap it up in a heavy canvas laundry type bag; or I’ve also used a moving blanket.
48,932
2,694
Like most of the seasoned repairmen here, I have to fear of gripping the spring in a gloved hand and snipping the wire. You'll be surprised how little power is released this way.
bwclock
Feb 17, 2015
329
223
I lay a towel over the mainspring and snip the wire. Sometimes i will hold the spring through the towel when I snip the wire and let it expand slowly. Whatever feels appropriate at the time.
BB
R. Croswell
11,880
1,820
I usually snip both sides of the "twist". The thought of skin being ripped by the twist bothers me more that the expanding spring, which as stated, "You'll be surprised how little power is released this way". I suppose gloves should be used, but I have trouble feeling what I'm doing when I wear my leather welding gloves. I usually use those common brown cotton gloves that are sold almost everywhere........... that is when I can find them. Always use face protection, and special care (gloves, towel, etc.) with larger springs.
48,932
2,694
My post should have read "no fear" not "to fear". Sorry :)
48,932
2,694
For sure, Will. I don't play that way with big springs ;)
Schatznut
Sep 26, 2020
1,235
611
SoCal
I usually hold the spring with a gloved hand and slowly untwist the wire with a pair of pliers. The spring release is usually pretty gradual and easily controlled.
That's the way I do it too. Maybe it's just the illusion of control, but I prefer the gradual release of tension rather than a sudden one.
Swanicyouth
Nov 10, 2019
354
100
49
Yes. I thought of that. I always use oil anyway. I haven’t taken this apart yet - but it may be a Waterbury star movement. I can see there are brass inserts for bushings now, but they look pretty small.
176,158
1,541,867
53,162
debbieb63
1,065
3,031
