• Upcoming updates
mainspring and strength
guychampeau
Feb 5, 2007
1,106
detroit, michigan (nashville too)
www.rattandson.com
I am asking this question just for discussion...all else being equal...width...length...a mainspring for an 18-size pocket watch...what would be the result of using a strength 02 instead of a strength 03 as stated in the factory guide...I have heard tell that it should not be an issue because modern mainsprings are alloy and the older original are steel....thanks...
doug sinclair
Aug 27, 2000
14,363
82
Calgary, Alberta
I had to check my conversion tables to be sort of certain of an answer. I suspect you are using Dennison numbers, but it am accustomed to dealing with metric. My table say that a Dennison .02 strength is equivalent to .019 mm, and Dennison .03 strength is .018 metric. If that sounds correct, there shouldn't be enough difference between the springs to make a difference.
180,048
1,570,685
54,361
mickri
911
3,090
