Made In England: Grandmother Clock
Discussion in 'Your Newest Clock Acquisition' started by Armando Alcaraz, Dec 3, 2019.
  1. Armando Alcaraz
    Armando Alcaraz Registered User
    Sep 4, 2018
    11
    Hello again, I recently came across this what I think is a Grandmother clock, stamped and labeled Made in England that has been sitting for over 42 years in a closet. I got it to run, ring and chime. It has 3 winder keyholes, a cylinder brass bob on a wooden dowel and no makers marks that I can find. One of the springs seem to be broken when I tried to check if it would wind. It spun in the barrel but will need to open it to be sure. I'm letting it run down to let off the over winding. It needs some TLC but would like some help in maybe finding out a maker and possible age range. I was told by the owner that it was a gift to her mother sometime in the 20's or 30's Thanks for all your help!!
    20191202_165622.jpg 20191202_165629.jpg 20191202_165642.jpg 20191202_165650.jpg 20191202_165704.jpg 20191202_165712.jpg 20191202_165722.jpg 20191202_165728.jpg
    Kevin W. likes this.
  2. Ticktocktime100
    Ticktocktime100 Registered User
    Nov 11, 2012
    920
    13
    Student
    France
    Hi,
    It's an English clock, as you've already found out. It looks to be a Peerless product to me. Peerless is regarded as one of the better English manufacturers. They made some excellent quality movements. Your clock looks Art Deco, so the 1930's does seem like the appropriate date for it.
    Regards.
    Armando Alcaraz likes this.
  3. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    4,291
    81
    Devon
    It looks more 1940s to me. I had a look through the reference book Clockmaking In England & Wales In The Twentieth Century but I couldn't find that movement.
    Iirc Peerless is a German trademark used by Bauerle Uhrenfabrik.
  4. Steven Thornberry
    Jan 15, 2004
    21,148
    717
    Ne’er do well
    Here and there
    I agree about Peerless. The back plate stamping, "Made In England," seems to compare favorably with a stamping used by Enfield between 1932 to ca. 1944. I refer to page 200, table 5.3, of Clockmaking In England & Wales In The Twentieth Century. Not certain, however.
  5. chimeclockfan
    chimeclockfan Registered User
    Dec 21, 2006
    3,814
    139
    Chime clock & gong studies.
    WI
    Not even close to Peerless, which was the common trademark of Mathias Bäuerle GmbH in St. Georgen, Germany. This is an Enfield Clock Company (London) clock, using a movement which was directly derived from a German BADUF pattern. Enfield was founded by Carl Schatz who was a shareholder in BADUF and made use of their proprietary movement patterns in many early Enfield clocks. Your clock was made no earlier than the early 1930's and is a fine example of its kind. I would suggest cleaning the gong rods with Slick Lube 50 or any equivalent to remove light corrosion.
    A mantel clock 'sibling' can be seen in this thread:
    Art deco enfield winchester chime.
    As referred to earlier, John Glanville's book 'Clockmaking in England and Wales in the Twentieth Century' wields further information pertaining to Enfield's origins and legacy, and is one of very few published books to document factory-made chime clocks from any company.
  6. jmclaugh
    Jun 1, 2006
    4,291
    81
    Devon
    Enfield's first Westminster chiming movement, the K1, is with very minor differences the same as the Baduf equivalent and was produced from 1932-40 but it has one set of hammers. If it is Enfield which I agree is very likely it is quite possible this movement was an adaption of the K1 or maybe Baduf also made a similar one this movement was based on. As I said it isn't in the book referred to above so there appears to be no source to confirm it.
  7. Armando Alcaraz
    Sep 4, 2018
    11
    Thanks to everyone who took the time to look at my clock and give it a go as to makers mark and model. I will be stripping it down and giving it a much need cleaning. I do have one barrel spring which is broken and now will be on the hunt for that. All in all, it keeps good time and has a very warm full bodied chime. Loving her nonetheless and giving her the attention she deserves.
