Lubricating jewels in mainspring barrel - oil or grease?
Discussion in 'Watch Repair' started by Mark UK, Mar 30, 2017.
  1. karlmansson
    karlmansson Registered User
    Apr 20, 2013
    1,930
    #21 karlmansson, Apr 1, 2017
    I just checked with a pro friend of mine, you're good :). Center wheels on pocket watches should be an excellent use for a high pressure, slow movement oil.
    The reason I got confused was because I re-watche done of Mark Lovicks videos where he uses a deep blue grease. I thought that would be the colour of your HP1300. The deep blue one is 9501 and your, red one is HP1300. 9501 is listed as a grease and HP 1300 as an oil. But it works for sliding applications as well. My friend tells me 9501 would be better on surfaces that separate an re-engage, such as clutch wheel teeth.
Similar Threads - Lubricating jewels mainspring Forum Date
Hamilton 940 roller jewel Watch Repair Mar 15, 2017
Any available information on "Liberty 100% Synthetic Lubricant"? Watch Repair Jan 20, 2017
Lubricant Advice Watch Repair Oct 31, 2016
Not a lubrication war, more of a gentlemanlike contest of fisticuffs Watch Repair Jul 5, 2016
Mechanical WW Omega mainspring no lubrication ? Watch Repair Jan 28, 2016
