Lubricating a wooden movement?
Discussion in 'Wood Movement Clocks' started by eskmill, Feb 15, 2003.
  1. eskmill
    eskmill Registered User
    NAWCC Fellow NAWCC Member
    Aug 24, 2000
    7,135
    With reference to American wood-plate, wood wheel, wood pinion, wire arbor clocks with no bushings, wood bushings or bone bushings; most agree no lubrication except for the 'scape wheel pivot in the brass bridge.
    On the other hand, Black Forest wood plate clocks generally have long rolled brass bushings pressed into the wood plates. These of course require lubrication.
    Les
  2. LaBounty
    LaBounty Registered User
    NAWCC Life Member NAWCC Member
    Aug 29, 2002
    3,438
    25
    Clockmaker
    Mitchell, NE
    Hi tin-injun,
    Here is a worth while thread on wooden works...
    old ref::Wooden Works Restoration
    Good discussion on bushing, cleaning, etc...
    David.
