Lubricating a clock with metal movement but wooden plates
Discussion in 'Clock Repair' started by kimgw, Apr 10, 2017.
  1. kimgw
    kimgw Registered User
    Apr 3, 2017
    22
    I have a postman's alarm clock that does not run.
    I have never worked on a clock with wooden plates.
    How do I lubricate the pivots?
    And if anyone knows anything about this clockmaker, I would be very interested! I'm intrigued by the little brass deer I found behind the face plate!
  2. kimgw
    Apr 3, 2017
    22
    I just realized it has metal bushings, so I'm assuming that clock oil is used.
  3. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,866
    watchmaker
    Western NSW, Australia
    Only enough to fill the metal bushings.
  4. R. Croswell
    R. Croswell Registered User
    6,642
    23
    Metal pivots in metal pivot holes (or metal bushings) need oil but sparingly. Oil and wood are a bad combination. Metal pivots in wood pivot holes do not require oil. By the way, nice clock.
  5. roughbarked
    Dec 2, 2016
    1,866
    watchmaker
    Indeed it is a nice clock.
  6. JTD
    JTD Registered User
    Sep 27, 2005
    3,947
    19
    The little brass deer is very similar to the mark used by Tobias Bäuerle & Son, of St. Georgen (Germany) though it is usually facing the opposite way.
    Tobias Bäuerle did make clocks with wooden works; however, I have never seen a wooden works clock with a deer as the anchor plate, Bäuerle usually used a little brass fish.
    The deer on your clock looks a little crudely carved and also the fixings look as if they might be later. I wonder whether someone made a replica of the Bäuerle deer and put it on, for some reason.
    It is a little puzzling but others may know more.
    JTD
  7. kimgw
    Apr 3, 2017
    22
    Thanks for the input! I have it up and running, but I haven't figured out the alarm mechanism yet. Every time I hang the weight on the alarm chain the alarm sounds until the weight hits the floor! And that thing is LOUD!!!! 🙉
    And yes, this clock was a sweet find I got ridiculously cheap at a recent estate sale! 😀
    Just started working on clocks last week! Learning as I go!
  8. JTD
    JTD Registered User
    Sep 27, 2005
    3,947
    19
    If you look at the instructions on how to set the 'alarum' on the label on your clock, you will find the answer to your continuous alarm question. The idea was to get you out of bed.........!
    JTD
  9. Burkhard Rasch
    Jun 1, 2007
    4,073
    10
    General-and trauma surgeon
    Twistringen
    the "little brass deer" actualy is a hare (admittedly with big ears),so it´s Phillip Haas as far as I can see. Nice clock,congrats!
    Burkhard
  10. JTD
    JTD Registered User
    Sep 27, 2005
    3,947
    19
    Burkhard, I don't think I've ever seen a Phillip Haas hare with a little coronet on its neck (as Bäuerle's deer has) and the 'ears' on this one look more like antlers to me.
    But you may be right - it is at least pointing the right way!
    JTD
  11. ballistarius
    ballistarius Registered User
    Oct 26, 2009
    702
    Architect
    Bilbao, Basque Country
    I am with JTD, Burkhard: it is not the Haas hare.
    Aitor
  12. Steven Thornberry
    Jan 15, 2004
    17,818
    20
    In the June and July 2010 issues of Clocks Magazine, Doug Stevenson did a two part article titled "Something Old, Something New." The article discussed these Schotten type movements. In July part of the article, Doug shows several examples of Haas's Hakenblaettchen, a hare that was really quite different from what is shown on Kim's clock. Given the carvings in the "ears," I presume they are meant to represent antlers. I tend to agree that this is Tobias Bäuerle's Hirsch (deer). Alas, Doug did not show anything from a Bäuerle Schottenuhr.
  13. kimgw
    Apr 3, 2017
    22
  14. kimgw
    Apr 3, 2017
    22
    #14 kimgw, Apr 11, 2017
    Help needed with this alarm mechanism
    Moderator's note: You'll notice the title change at this point. Two threads were merged to keep things together. - shutterbug
    I have a Tobias Bäuerle alarm clock.
    I'm not sure how the alarm hand should be attached.
    Could someone advise as to how this should be?
    Pictures show how it is now. Currently, the alarm sounds no matter where the hands are.
    Thanks!
  15. shutterbug
    34,335
    29
    Re: Help needed with this alarm mechanism
    Can we see the actual alarm mechanism? The only thing that comes to mind right now is an electric/battery powered alarm, which seems unlikely for a clock that old.
  16. Randy Beckett
    Randy Beckett Registered User
    May 23, 2012
    2,422
    31 yr. employee of American Electric Power Company
    Mt. Pleasant, Tx
    #16 Randy Beckett, Apr 11, 2017
    Looks like some form of sear/trigger mechanism to trigger the alarm. Will that top right lever move to catch behind the top end of the lever which wraps around the center shaft?
    Looks like you might have to set the alarm, then pull back the hammer to "cock" it before pulling up the weight. Or something like that.
  17. JTD
    JTD Registered User
    Sep 27, 2005
    3,947
    19
    Shutterbug, this clock seem to have got a number of different threads started. It is a wooden movement Bäuerle wall clock ('Postman's alarm' style) and if you look at the post headed 'lubricating a clock with metal movement but wooden plates', which was the original posting, you will see photos of the whole clock.
    JTD
  18. shutterbug
    34,335
    29
    Thanks, JTD. That makes things difficult to work with, so I've merged the two threads into one.
  19. kimgw
    Apr 3, 2017
    22
    It's a weight driven postman's alarm clock.
    I really think that the alarm hand is simply not on correctly, but I don't know how it should be. Here are some extra pics without having to take the case apart again. The case is put together with wooden pegs and tiny nails. View attachment 339798 View attachment 339799 View attachment 339800
  20. kimgw
    Apr 3, 2017
    22
    Sorry! It was a different topic so I thought it needed a new thread. New to the forum! My apologies!
  21. Burkhard Rasch
    Jun 1, 2007
    4,073
    10
    Twistringen
    I stand corrected,Tobias Bäuerle indeed! Should sharpen my eyeglasses!
    Burkhard
  22. kimgw
    Apr 3, 2017
    22
    There are instructions for the alarm on the inside door. According to it, you turn the inner hand counterclockwise until it reaches the hour you want the alarm to sound. Then you hang a weight. When the clock strikes that hour, the alarm goes off. You have to remove the weight to make it stop or it will stop when the weight is on the floor of course! The problem is, when I hang the weight, the alarm goes off no matter where the time is. Thus, I think the alarm hand is not set up correctly to trigger the alarm.
    The wire that wraps around the shaft is connected to the alarm hand. The pics show it the way I found it when purchased. View attachment 339851 View attachment 339852 View attachment 339853
  23. leeinv66
    leeinv66 Super Moderator
    Donor NAWCC Member
    Mar 31, 2005
    8,000
    12
    Industry Specialist
    Launceston Tasmania
    This is an unusual set up Kim and not one I have had any dealings with. But something with that steel wire contraption that is attached to the hour pipe doesn't look right. It looks like the tail of it should sit in the middle of that brass bracket. I believe that tail should interact with the other steel wire that hangs down to somehow trigger the alarm. Least, that is how it appears to me.
  24. Randy Beckett
    May 23, 2012
    2,422
    Mt. Pleasant, Tx
    Do you know what the purpose of that wire, or spring, is that is anchored at the middle top and goes to the center shaft behind the hour gear?
  25. kimgw
    Apr 3, 2017
    22
    Well, we can close the alarm topic!
    I figured it out! Hallelujah! 😀
    The alarm hand shaft has a notch in it. The hands arbor (terminology?) has a raised piece that slides into the notch when the hour hand lines up with the alarm hand. The long wire is a spring that pulls the alarm shaft toward the movement. The shaft is attached to an arm that sits in a slot blocking the alarm lever. When the shaft slides over the raised area, the alarm arm shifts and allows the alarm to ring! I'm so excited to have this clock working!!! 😀
    Thanks for everyone's tips!
    View attachment 339878 View attachment 339879
  26. ballistarius
    Oct 26, 2009
    702
    Architect
  27. kimgw
    Apr 3, 2017
    22
    That's awesome! And thanks for those pics! I've been searching everywhere for a picture of the T. B. brass deer cutout! My clock has the engraving on the back of the wooden case and the brass cutout, but for some reason, the cutout is leaping to the right! So far, no one has seen one like this!
  28. ballistarius
    Oct 26, 2009
    702
    Architect
    Hi,
    In fact I didn't remember I had that movement:whistle: It must be currently stored inside a cardboard box somewhere (I hope I wrote something on it...) No clue on why your stag is looking to the other side, but there are lots of variations on these BF clocks!
    Aitor
  29. kimgw
    Apr 3, 2017
    22
    I really think that the only reason it's leaping to the right is that it simply wouldn't have fit the other way because of the way the alarm is set up! 😀
  30. ballistarius
    Oct 26, 2009
    702
    Architect
    Surely it's just that. They had sets of cutouts looking right and left to suit different movements:clap:
    Yesterday, while I was answering to you, I thought for a moment: 'Well, if the stag on my movement would be looking right, maybe its back leg would interfere with the lever and coiled spring near...' then I dismissed the idea:cool:
    Aitor
Similar Threads - Lubricating clock metal Forum Date
zeeland colonial 4 tube clock info Clock Repair Yesterday at 10:20 PM
Lubricating Hammer Pull Levers for Tubular Bells Clock Repair Sep 2, 2017
Lubricating Open Springs Clock Repair Aug 17, 2015
Cleaning and lubricating Black Forest clocks Clock Repair May 5, 2014
lubricating an new spring and other questions Clock Repair Mar 12, 2013
