Lorch Schmidt 'Triumph' Mandrel
Discussion in 'Horological Tools' started by gmorse, Jun 26, 2019.
  1. gmorse
    gmorse Registered User
    11,247
    1,555
    Retired from Xerox
    Hi,
    I've just acquired an accessory which I've been after for some time, a headstock mandrel for my 6mm Geneva pattern lathe. Although it was probably made before WWI and some of the plating is a little spotty, it functions perfectly, with very clean flat clamps and good tight bearings. It did cost a little more than I paid for the complete lathe, but that was probably around 20 years ago, so I think it's worth it.
  2. karlmansson
    karlmansson Registered User
    Apr 20, 2013
    2,604
    Doctor
    Linköping, Sweden
    Congratulations!
    I have one just like it but mine is missing the knob for the plunger.
    It is a really useful tool for boring out worn bushings and achieving uprightness. I hope to get some use out of mine for actual plate manufacturing further on as well.
    Is yours right or left hand?
    Regards
    Karl
  3. wefalck
    wefalck Registered User
    Mar 29, 2011
    519
    37
    Geochemist (Consultant)
    Paris
    The one on the picture is for having the headstock on the left, as the flat is behing. Had one exactly like this, with a brass disc, but it was for having the headstock to the right. At some stage I was able to obtain a left-sided one, but with a plated cast iron disc, which doesn't look quite as nice and has less momentum due the difference in the specific density betwenn brass and iron.
