Jerry, I'm just going to have to get myself some type of Mill. I have a Watchmaker's Staking Kit but the Anvil is often too limited in size for clock wheels and parts. Thanks for that explanation. It just wasn't clear to me what you meant by "pocket".
RC I was kind of expecting you to jump in with your usual probing questions. You seldom disappoint.
In no particular order;
No, I don't use LocTite 262 anymore. Mostly because the tube I had on hand was too old and the little plastic nozzle was always plugging up. I would constantly need to poke or drill through a cured plug in the application nozzle in order to dispense product. I then decided to try Loctite 638, which is specifically formulated for sleeve retention. However, I had the same problem with the application tube plugging up since the packaging/dispenser was basically the same as before. I have tossed both of those tubes out because they were too old and the nozzles were getting pretty "chewed up" with my constant efforts to re-open them back up. Evidently the packaging was not intended to be used for small, frequent applications of the product. Most recently, I've purchased the 680 formula and have been very pleased with an improvement in the package dispensing tip. It does not clog and gives me the ability to apply very small amounts to my bushings.
The 680 Formula has directions for slip, press and shrink fitted assemblies. It is designed for
fitting of cylindrical parts where low viscosity is required. I really like the stuff. Have I set up an engineering lab to test its effectiveness, RC? Nope, I sure haven't. Have I looked at specs reported by their Engineers and Tests on the product? Yes, I have. Do I know that some press fit bushings without additional retentive measures are relatively easy to displace? In my experience, yes they can be. That's not to say they are loose. I have chosen to have some of the 680 on hand, and I have decided to use it rather than lose it to an expired shelf-life.
Why did I get away from using LocTite? For a while I worked with peening and reaming press fit bushings, but only when they fit didn't feel as tight as I would like it to. I experienced this most often with a batch of bronze bushings I ordered from Timesavers (as I recall). It's a fast and effective method of setting a slightly marginal bushing and I think it is good for me to have it in my toolbox.
I wouldn't use LocTite on the joint in question unless the Gear is to be removed for adequate application of the product. Even then, the joint is not a Cylinder, nor is it a series of threads so I don't see it as lending itself to the use of LocTite. If, for whatever reason, the pocket is not to be deepened to expose additional metal for staking, and if I couldn't stake securely with the current joint form, I would probably use very small amounts of silver bearing solder instead of LocTite. This is an EW so even a soft solder like Tix would probably provide more than enough bonding in the joint.
Did I miss anything RC?
Bruce
