Looking for watch maker to restore 1914 Waltham pocket watch
Charlie Ryan
Dec 10, 2017
129
57
Annapolis, MD
Hi All
I have my grandfather's Waltham which is in need of complete restoration including the dial. There's also water damage in the movement.
Can anyone recommend someone?
Thank you
Charlie
musicguy
Jan 12, 2017
8,026
4,516
New York State
Send me a Private message and I will give you some referrals
Rob
musicguy
Jan 12, 2017
8,026
4,516
New York State
Moving question to the watch repair section for more responses.
Rob
musicguy
Jan 12, 2017
8,026
4,516
New York State
Can you post some photos of the damage. I did contact one of the
people I refer people to and I guess it all depends on the amount of water damage.
None of the watch repair people I refer to restore dials but
a replacement dial probably can be fairly easily sourced. This will be an expensive
restoration but since it's a family watch I do understand why you
want to have it repaired.
Rob
John Runciman
Aug 13, 2003
501
84
Seattle, WA
pictures really are needed unless you want us to use our imagination and some of us have seen a lot of really bad so that means I can imagine a lot of bad. It's a porcelain dial a lot of those can just be washed even find cracks will come out in the wash if the dial's chipped that would be an issue. But rust anything that resembles visible rust you might end basically with a new movement or somebody cannibalizing a movement for your movements.
DeweyC
Feb 5, 2007
2,517
1,086
Baltimore
www.historictimekeepers.com
Here are some pics. Ratchet wheel is rusted in place but gear train moves. HS is intact.
View attachment 671691 View attachment 671692 View attachment 671693 View attachment 671694 View attachment 671695
Ok. First, it looks like the case has problems. Stem and and crown and I cannot tell if the front bezel is present.
Now for the bad news. From the visible damage, you can expect all steel is destroyed. This means the pinions, the balance and balance spring. Perhaps not; but likely from is shown.
The good news is that most parts can be obtained from a donor movement. But if the balance is destroyed, it must be replaced with one that will have a different serial number than the rest of the movement.
All of this will involve significant costs. The dial damage will respond from being soaked in ammonia or denture cleaner.
The philosophical issue is a what point is it still grandfather's watch? This is a highly personal determination but it should be addressed before spending much money.
Dewey
musicguy
Jan 12, 2017
8,026
4,516
New York State
Reactions: John Runciman
Ethan Lipsig
NAWCC Gold Member
Jan 8, 2006
2,526
2,461
72
Pasadena
Charlie, restoration of your grandfather's watch will be expensive. The restored watch will not be original for the reasons Dewey set forth. If you do not plan to use the watch, it would make more sense to leave the movement as is, and just give the watch a cosmetic overhaul, e.g., clean the dial, etc. The watch then will be a decent looking memento of your grandfather. If you want a working pocket watch, it would be far less expensive to buy one that's already in good working condition. Your grandfather's watch is a 12-size Model 1894 Grade 225. About 550,000 were made. It is not a rare watch or a valuable one, except for its sentimental qualities. I just checked eBay to see what a good example of a watch like it sells for. $66 was all it took to get this one: 1931 Waltham 12s 17j Pocket Watch Running grade 225 model 1894 | eBay.
klokwiz
Feb 4, 2009
1,462
95
Annapolis, MD
Charlie,
I see that we are local to each other, if you would like i will give your watch a visual if you wish to have an in-person opinion. Private message me if you would like to do this.
Joe
168,146
1,466,311
48,110
Stevemn
2,955
