Looking for pictures of an original case for "Remember" clock
Discussion in 'Clock Case Restoration and Repair' started by David Dewey, Dec 28, 2011.
  1. David Dewey
    David Dewey Registered User
    Dec 22, 2011
    Curator, Cultural Facilities & manager city's Perf
    Northern California
    Greetings,
    I recently acquired a Vienna Regulator clock that the case has been heavily modified--basically it has lost it's top & bottom, and door side trim. See pictures. the existing top & bottom are somewhat crudely made, and nailed onto the case with visible nails, as are the door side trim pieces. This case is a little unusual in that the dial is behind a "window" in a wood front panel, then there's a rectangular window below that to expose the weights and pendulum.
    I'd like to replicate the top & bottom, but need some pictures (measurements would be even better!) of what they looked like.
    The mechanism is made by Gebr. Resch of the Resch Brothers in Ebensee, Austria and is known as "Remember Clock Co." I do note that, other than the surface veneer of Walnut, the case appears to be made of a soft wood, like pine. Is this "normal"?
    Many thanks!
    David D.
  2. Scottie-TX
    Scottie-TX Registered User
    Donor Sponsor
    Apr 6, 2004
    938
    12
    Mesquite, TX
    #2 Scottie-TX, Dec 28, 2011
    Yeah, I don't know the specie but yeah; These are usually made of construction grade, common, relatively soft wood. Most often the backboard has a lively quarter or bookmatch crotch veneer of possibly walnut, rosewood, or mahogany. Often the base piece has a bookmatch also of same or complementing veneer. Sometimes the door frame front only has a veneer. Often the remainder of the case is faux grain, ebonised, or dark toning. If you remove that trim on the door you might find shadows of original trim there - often some kind of pediment on each corner.
    Top is most often treated with an inverted cornice molding flush with top of case. To the top then often is some kind of suitable ornament - gesso, wood carving, architectural designs, etc.
    Do you suppose that wood panel surrounding the dial is original? I suspect it is not. Most viennas have a "floating" dial with no wood surround. Now, if that is original it may aid in learning the original design of the clock.
    If you haven't already, avail yourself of this collection from our members:
    VIENNA CLOCKS
    I note one Resch, P10 and another by BOGEY, P12. Bogey's would mirror my goal for yours.
  3. David Dewey
    Dec 22, 2011
    Northern California
    HI Scottie,
    Re: the wood surround. If the door is original, which all signs indicate it probably is, I think that is the way it was originally made. The outside surface has a thin layer of walnut veneer over softwoods. Also the circular surround and the door glass trim is much fancier and nicer than the modifications.
    Yes, I did check out the threads you mentioned, and saved the photos. Nothing like this case door though. I would suspect, based on the serial number, that this clock is pretty late in their production, probably close to 1900.
    I would also guess that it was likely two-toned, due to the un-veneeered side wood, which would have to be faux grained or stained dark to hide it, and the staining would be the more economical way to cover it.
    Thanks for you help!
    Keep those cards & letters coming folks! :)
    David D.
  4. soaringjoy
    soaringjoy Registered User
    Donor Sponsor
    Feb 12, 2009
    7,240
    14
    Well, Gebr. Resch was taken over by Junghans in 1901 and
    the "Remember" logo was also introduced in that year.
    This is a nice thread on the topic, also noting a NAWCC bulletin
    article on Resch and Remember:
    http://mb.nawcc.org/showthread.php?t=78573&highlight=Resch
    These plainer case styles came up just around WW 1, afaik, because
    the traditional "Alt Deutsch" cases were considered old fashioned by
    some, leading to sales drops. The makers eventually added these more
    "modern" cases to their programs.
    Jurgen
  5. David Dewey
    Dec 22, 2011
    Northern California
    Hi Jurgen,
    Unfortunately someone (in authority) in the past made the statement that the "Remember" was added in 1901, but documentation and existing clocks show that it was done much earlier than that, back when the factory was first moved (I'm on dial up, so don't want to take a half-hour looking for the site that clears this up).Note that the clock in the thread you linked to is about 100,000 earlier than mine and has "Remember" on it. However, "Remembrance" was added in 1901--probably where the confusion started. For being such a prolific maker, I am surprised that there is no correlation available between serial numbers and dates--you'd think we could at least figure out decades, or some year range just by looking at existing clocks & making some assumptions on production numbers.
    But back to my case dilemma! This front door treatment is unique enough that I would think another example could be found. Hope hope hope!
    The attached picture is of the stampings on my clock's plate--not the best photo, I'll have to take another sometime, but you can see that mine is from the 200,000 series.
    Thanks all,
    David D.
  6. David Dewey
    Dec 22, 2011
    Northern California
    Scottie,
    Well, I took off one of the door side trim pieces--not hard, only five 16 ga. finishing nails holding it on. All that I found was raw lumber--looks like maybe some hide glue on it, so no hint of piediments or anything. Rats. Although the clock that was suggested to me on German eBay with a similar front has just straight lumber additions on the door edges.
    I wonder where else I can look for pictures of Resch clocks?
    Thanks!
    David
  7. leeinv66
    leeinv66 Super Moderator
    Donor NAWCC Member
    Mar 31, 2005
    7,999
    12
    Industry Specialist
    Launceston Tasmania
    David, before you go modifying the case of this Resch too much, I do not believe it is too far away from what it would have been originally. Take a look at this link and you will find a two weight Resch in a box style case. If yours had the beveled glass fitted, it wouldn't look too different to this one.
    http://www.liveauctioneers.com/item/9296283
  8. David Dewey
    Dec 22, 2011
    Northern California
    Hi Peter,
    Wow, that's great! The photos show some details I've wondered about. The pulleys match the one that came with the clock--rats, there was a mate on eBay, I didn't bid high enough and someone else bought it.
    The soft case wood is also visible in the pics, so I do believe that the main case itself is original. I would say that my clock is either a cheaper model, or maybe the door glass was replaced, losing the beveled, leaded glass.
    Wish the auction showed the serial number!
    But we're getting closer! Many thanks!
    Oh, it also gives me a better idea of the size of weights used too.
    David D.
  9. clockinit2
    clockinit2 Registered User
    May 5, 2012
    159
    Los Angeles
    Hi leein66,
    The pictures with the beautiful bevel leaded glass has been most helpful to me. I was looking for information on this case that I bought a whiles back. Just like David I wanted to know what mine should look like. On the back of the box there is a stamp that says Ludwig Krandisch , Uhrmacher , Stein & Donau , est 1874. but there is nothing on the two weight movement. However there is a 09 stamped on the movement plate. Here are some pics.
    I actually got it like this ,the only thing is I just replaced the glass this week. I was wondering who is ludwig that is stamped on the back of the case.?. Thanks
    DSC05164.jpg DSC05159.jpg DSC05160.jpg DSC05161.jpg DSC05162.jpg DSC05163.jpg
  10. David Dewey
    Dec 22, 2011
    Northern California
    Great pics, just what I think I've been looking for. Could you post pics of the bottom of the case, and an end view of the door, so I can get a better idea of the door edge trim shape? I have found no markings on my case, just on the movement. It looks pretty obvious to me at least, that the top and bottom of my case have been altered, as well as the door side edges. for what reason--I have no idea--maybe the top and bottom to fit the wall where it was hung??
    Thanks!
    David Dewey
  11. clockinit2
    May 5, 2012
    159
    Los Angeles
    #11 clockinit2, Sep 1, 2013
    here are more pictures of the case. I sure wish I knew how to fit leaded bevel glass I would fit clear bevel glass to the case.
    David and what does the back mounting plate for the movement looks like ? what is the length on your pendulum? How much does the weights weigh, and are they the fancy engraved weights?. I did not get those with mine when I bought it..
    DSC05172.jpg DSC05165.jpg DSC05166.jpg DSC05167.jpg DSC05168.jpg DSC05169.jpg DSC05170.jpg DSC05171.jpg
  12. David Dewey
    Dec 22, 2011
    Northern California
    Egads, the backs look nearly identical! Here's some pics of the pendulum and my wheels. Note the pendulum has the clock serial number on it even! According to my bath scales, it weighs around one pound. I too, did not get the weights with my clock.
  13. clockinit2
    May 5, 2012
    159
    Los Angeles
    HI David,
    Thanks that give me a good reference of what I need to purchase as far as the pendulum and wheels. If only I knew what the movement mount look like. It looks like you are missing a few pieces of wood ath the top and bottom, but you should be able to find something close to what it looks like.
    Thanks again
  14. David Dewey
    Dec 22, 2011
    Northern California
    I'll photograph that tonite--I don't remember what it looks like either! :)
    In some ways, I think my clock was more complete than yours--except for the case mods.
  15. David Dewey
    Dec 22, 2011
    Northern California
    Sorry, took longer than I thought to take the pics. I'm also posting a pic of the pendulum scale piece and the stampings on my works--did you find any on yours?
    From looking at things, it appears that my mount base has been moved in the case, or replaced. Another mystery! It looks like you could make a base with a little patience and a small lathe--or even a drill clamped in a vise and a file!
    My clock only came with one pulley, I found the other one on eBay, so they are out there somewhere (maybe with The Truth?? :p )
    Note that the pendulum hangs from the mount, not the works, explaining the slot in the pendulum.
    mounting base & works web.JPG Mounting Base side web.JPG pendulum align plate web.JPG pulley web.JPG works stamping web.JPG
  16. clockinit2
    May 5, 2012
    159
    Los Angeles
    Thanks david,
    i did not get the mount with mine . The gong is missing also. But this gives me a good picture of what it should look like . Oh ! There is no stamp like that on my movement. There is however a 09 stamped on there. It may not be the original one for that case. I will take my time and sort it out. Thank you for your input.
Similar Threads - Looking pictures original Forum Date
Looking for bulliten article - restoring/cleaning alabaster case Clock Case Restoration and Repair Jan 14, 2016
looking for some advie 1790 Longcase Clock Case Restoration and Repair Oct 4, 2015
looking for missing ball feet from Birge & Mallory Clock Case Restoration and Repair Jan 12, 2015
looking for a key hole escutcheon Clock Case Restoration and Repair Dec 29, 2014
Need pictures of the medallion on an Ansonia "Troy" cabinet clock Clock Case Restoration and Repair Dec 4, 2013
